Same settings for multiple objects
Is it possible to set the same settings for many of the same objects?
I build the fence and using the same object only in larger quantities. Each time set the same settings for a single object is a little time consuming.
Is it possible to enter the settings for the larger quantity of the same object?
Load the part of the fence that you want to replicate.
Go to Create > New Node Instances, that will create as many as you want, you now only need to position them. Is that what you mean, if not post again with some more information as to which object this is.
Thats it ,thanks man :D
