Moving several items has stopped working
Hera
in The Commons
In earlier DAZ versions it was possible to select several items in a scene and then move them in either directions, re-size or rotate them et cetera. In daz 4.14 that functionality appears to have stopped working. Clicking on several items only selects one, the first one clicked on. Very tedious if you need to move several objects
A quick workaround is to select items and create a new group. Then move the group.
Or Ctrl-click in the Scene pane.
Also check what tool you have active.
I test with translate, rotate... every one there is, the error remains
I've never seen that functionality without grouping objects, or using something like https://www.daz3d.com/advanced-collective-transform-tools
It's quite a tedious work-around to keep moving objects in and out from groups when moving them around, I've noted. Is there a way to fix this, I used this ability a lot!
