some issues with eyes in Iray
I have had this issue a couple times now, and its beginning to drive me a little crazy. cause the only way I know to fix it is delete and redo.(hope it fixes it.) I cant seem to locate the exact problem. whike this is a look perfect if i want to have a creepy character... not good for my intended uses. anyone have any clues?
3839 x 2160 - 775K
3840 x 2160 - 1M
It's an Iray thing with mesh that is too close to another mesh.
Helps if figure is at or near centre. Also look for some cornea/eye morphs ... several characters come with a bulge morph of somekind to apply to the eyes to help alleviate the situation.
There are a few freebies also, at least one at sharecg.com. Another one might be over at Deviantart.com.
I've had this problem and there are two possibilities:
Check if your eye moisture or cornea surfaces have thin walled turned off. they should be on.
Otherwise, check if you have the correct UV maps set for your eye surfaces. They should be base female unless your skin uses a different one.
