why is suddenly my Daz Studio being disrupted?
DrekkanDrekkan Posts: 460
edited November 2020 in The Commons
K so I installed the 'dazCentral' thing but for some reason whenever I start Daz now I get this popup first (pic 1) then after I click ok I go to the main Daz inferface and it looks mostly white (pic 2) what is goin on here?! it must be to do with the DazCentral installation as I've never had this happen before. I uninstalled it but this message still keeps popping up when I start Daz and the interface still is messed up. Help pls.
632 x 460 - 227K
1919 x 1079 - 338K
Post edited by Chohole on
  • NorthOf45NorthOf45 Posts: 5,929
    That usually happens when there is an update that executes when Studio is running. Re-install Studio from DIM or the standalone installer and check your library locations. Make sure your DIM setup (if you use it) is still intact, Central is known for messing with it, especially if you use non-standard locations.
  • DrekkanDrekkan Posts: 460
    gottit. Thankyou :)
    Gotit too! NEVER USE AGAIN THE BUGZ CENTRAL!!!
    It's just TERRIBLE!
    Thanks!
    Caveat: From the splash screen it looks like the OP is using DS 4.12. Unless they have a saved installer for it, reinstalling now with either DIM or manual download will install the upgraded version (DS 4.14).
    yeah now my previously saved Daz scenes won't load up *cries*
  • fastbike1fastbike1 Posts: 4,085
    @Drekkan
    Changing Studio versions won't disrput previous saved scenes unless your contents paths are different with the Studio update. The Studio update shouldn't change  content paths either.
    Right. I always have that backup, so I assume everyone else does, too. Haven't installed the new version, so I didn't think of it. If the OP didn't have a backup, it's too late for that, anyway.
    fastbike1 said:
    @Drekkan
    Could be that Central mucked it up, from what I've read. (Note: @fastbike just put plain text after the @ for the auto-notification. Forum software will generate the code)
    ah you gotta be kidding me so now all my work saves are unloadable? can't I reinstall the previous version back?
    Check your library paths in Studio to ensure that they have not been changed (Content Directory Manager). If the library with the installed content has been re-defined, your saved scene files might not be able to find it.
    so its a case of just re-directing them?
    If they were changed, yes. Edit the path to point to the proper folder, if that is the case.
    thx guys.
