Quick question - copy the location of a prop
This is probably (should be) an easy thing but I can't seem to work out to do it.
I have a prop in a location in one scene and want to copy/duplicate those co-ordinates to the same prop in another scene (animation scene rather than separate files)
I can copy the x,y,z etc. manually and paste them but surely there is a simple copy/paste operation from co-ordinates/selected properties?
Many thanks.,
  • - You can save prop as scene subset and load it in place from saved preset
    - You can select prop and save as Pose Preset and load as Pose in new scene
    - You can Edit>Copy Selected Items then Edit>Paste to Selected Items (not sure if this info gets lost if you close the scene in between Copy/Paste, but in the same scene it will work)
    Keep in mind if some props are parented to a group/null/figure/prop you're pasting a pose of the Prop you selected not the parent tree you may get different results. My suggestion is using Scene Subsets as the most accurate one.
  • Many thanks.
  • alan bard newcomeralan bard newcomer Posts: 2,426
    edited November 2020
    I have hundreds of scene-subsets .. but I noticed they took my longer then my  scene saves ...
    so I did my next scene-subset as a scene save .. still saved it into the place I put scene subsets
    took 5 secs to save a cube as a scene, one minute and 30 secs to save as scene subset
    one is label "scene" one is label "set" but they both load using the merge into scene
    In fact the only difference between scene and subset (other than the time to save
    seems to be the location.
    one is in your content library the other wherever you save your scene files
    https://www.daz3d.com/forums/discussion/433336/scene-subsets#latest
    Post edited by alan bard newcomer on
