Can Aiko3 be put in VRChat?
ltmiroku_20bbf1c990
I'm uncertain if this is the right place asking this, but i am curious if either of these models can be rigged and setup for VR Chat "Aiko3/4, Victoria 4, NearMe, etc" i seen a tutorial about using Genesis 8 and it talks about how easy it is using this model. But the problem i have ithere is i don't have as many moprh files or clothing files to pull off a cute enough design of what i have planned.
I don't have a good amount of funds to simply supply genesis 8. So is there a tutorial/video on doing the models properly? and can they be done?
Aiko3? btw what is VR Chat?
they have TAFI for that
https://www.maketafi.com/
I am not sure if using DAZ models is allowed under the EULA if being accessed online
they cute designs!
i'm not looking to share the model if that was the thought of the eula concern. Is there an easy to follow guide?
Also this is vrchat https://hello.vrchat.com/
if all files remain on your computer and nobody can access it,
I still am unsure how VRchat works data wise,
you cannot use DAZ content in MMO programs for example as it is uploaded to a server somewhere
the mesh data is not staying on your computer others have access to it
and some like SecondLife expressively state they will claim rights to anything you upload
I suspect VRChat is the same
a moderator should explain and you also should be asking DAZ on Zendesk not a peer to peer forum
Thanks for the help and heads up. I have sent in a message on Zendesk, but if a moderator would like to chime in as well would also be welcomed support.
The legal mumbo jumbo is always a fun tricky thing i've learned that its always good to look up and ask, then to get bit later. ^.^
