Recommended Mirror Shaders
DDCreateDDCreate Posts: 1,421
I have a few environments that have floor to ceiling mirrors that can sometimes be tricky to work with due to what/how they reflect. I've heard that there are perhaps some metal shaders that work like mirrors. I wondered if anyone out there had a commonly used go to/work around when it comes to mirrors. Thanks for any advice!
  • HylasHylas Posts: 5,323
    edited November 2020
    What's wrong with just setting Base and Glossy Colour to white or grey, Metallicity to 1, and Glossy Roughness to 0 (or 0.1)? Instant Mirror.
    Post edited by Hylas on
  • DDCreateDDCreate Posts: 1,421
    Well I don't know. I'll have to try that. I am not as well versed in that sort of thing I guess.
    Apologies, I came off as standoffish!
    I think I took a look at the number of your posts and made some wrong assumptions.
    Give it a try and report back!
    Way back when Iray was first introduced, someone suggested using the Silver Metal shader from the default resources. Turn the Glossy Roughness parameter down to a tiny fraction, or off altogether, unless you want an actual metal mirror with no glass.
    Post edited by SpottedKitty on
    Ha! No worries at all. I guess that means my past posts made me sound smarter than I am? Yay me! lol Thank you for the directions. It does give the effect i was looking for. :)
  • vonHobovonHobo Posts: 1,715
    This one says it comes with a mirror finish shader. Could come in handy.
    https://www.daz3d.com/1stb-mirrored-finish-props-and-vignettes
    OK. I came here because I too needed a mirror shader.
    So after trying all the suggestions here and failing (see Screenshot 1) to get a mirror finish with a metal shader or base color or anything for that matter. I finally just gave up and purchased the mirrored finish props:
    With one click I got screenshot 2. Mirrored sunglasses! Thank you!!!
    Was it worth $16 ??? I guess if it saves me 3 hours of trying to get the other shaders to work, then yes. Ugh!
    822 x 683 - 907K
    1390 x 754 - 1M
