Luxus for Carrara Render issue/Question.
Akulla3DAkulla3D Posts: 131
Anyone know why her ears are reflective? (see attached) I checked all the shaders they are correct and all the same reflection and shine.
Thanks.
400 x 600 - 287K
  • ProPoseProPose Posts: 550
    I'm not sure what character that is, or if the ears are a morph or a separate object such as a prop. My first step would be to get rid of all the shaders associated with that item and rebuild it from scratch using luxus shaders.
  • JoepingletonJoepingleton Posts: 746
    I am not sure why the ears are reflective is all the settings are the same as the rest of the body. You normally get this when the reflection shader is set to high. Have you tried using the settings from this thread [ http://www.daz3d.com/forums/discussion/29998/ ]? I have had very good results using Jon's settings in Luxus for Carrara.
