Download only and Install on an Offline PC
info a388info a388 Posts: 0
Is it possible to download the installer and then Install the program to an offline PC
    The installer can be run in offline mode, but to install content you'll need to download the ZIP files on a separate machine and transfer them to the system you want to use them on. Place the ZIP files into the folder (default is \Users\Public\Documents\DAZ 3D\InstallManager\Downloads ) and then, after loading it in Offline mode, you can go to the 'install' tab and you can install the files as needed.
  • prixatprixat Posts: 1,627
    edited August 2014
    That's an interesting idea from Herald of Fire, have a DIM on each machine:
    Have DIM on the download machine:
    You can untick the 'delete after download' and 'install after download' options.
    You can even tell it which folder to keep the downloaded packages in.
    The second DIM on the offline machine can still be used to install packages if they are copied over to the right folder.
    Post edited by prixat on
  • namffuaknamffuak Posts: 4,514
    edited August 2014
    I wrote a step-by-step on this here.
    I do my downloads to a laptop with a USB disk drive at a wi-fi hotspot and then drag the results home to install on my main system.
    Post edited by namffuak on
