Problem with Spin modifier
Mosk the ScribeMosk the Scribe Posts: 908
edited August 2014 in Carrara Discussion
I'm using the DAZ Humvee in C8.5 Pro.
I placed a spin modifier on the back wheels for .15 revolutions per second (on the x axis because that's how these wheels are set up) and it works fine.
When I place a similar spin modifier on the front right or front left wheel (on the z axis, because those wheels are oriented differently), it works fine for the first 1.5 seconds (which equals 1/4 of a revolution) -
The orientation of the wheel reads 0 (for X), 90 (for y) and -0 (for z) at this point.
Rotation is -0, 0, and -87.75
The next frame animation still looks okay but rotations now has changes to x and y values,
-1.82, 1.82, and -90
And the following frame, the wheel flips around -
Rotation 30, -180, -85.50
From here the wheel continues a slow backward rotation on the z axis all the way down to 0, and then back up to 87.75 at 4 sec. 23 frames
At 5:00, the wheel flips back around to the correct side, rotation flips back to
0,0, 87.75
and things animate properly through 8 sec 7 frames -
with rotation of -0.0.-87.75.
At 08:08 becomes -.6, .6, -90
And at 08:09 the wheel flips again to rotation 30, -180, and -87.75 and continues the backward rotation
This weird behavior happens with both front wheels.
Neither have any keyframes - just the spin modifier.
Any ideas on what could be causing the problem (or best ways to work around) - I'll try manually resetting wheels to 0 rotation when they flip, but not sure what's cuaing problem in the first place. Using linear tweeners without any easing.
EDIT - tried typing in new values for wheel rotation in the motion panel, and that does shift wheel, but it replaces my values with its own - so if I type in x 0, y 0, z -90 I still end up with -15.91, -4.72, and -270
Thanks for any help. (I had hidden some vertices in model room - but don't think that should cause this kind of behavior; don't have an animation track and no idea what's causing this override of my normal values)
Post edited by Mosk the Scribe on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,789
    First of all make sure the hot point is centered on the hub for all spinning parts
    This seems like your issue
  • Mosk the ScribeMosk the Scribe Posts: 908
    Hey Wendy-
    I looked at the hot point and it seems centered and isn't animated (checked sequencer and looked at graph editor as well)
    Eventually I just loaded a new humvee - and that one works fine
    Somewhere along the line I must have broken the first humvee - even though you'd figure those are built to be durable. I know I'd hidden some polygons - maybe I accidentally deleted some. Found a rotation morph on a level of the humvee I hadn't looked on as well - and that too was giving the strange behavior on the broken humvee.
