Lollipop hair morphs missing?
PulpArtstPulpArtst Posts: 88
http://www.daz3d.com/lollipop-hair
I loaded V4 and then loaded the V4 version of this hair, but I can't find the morphs as they don't appear under Shaping. I noticed this with another hair the other day. Is there a trick to get the morphs to show? They show on most hair correctly.
Interestingly enough when I load the accessories like the bow and hair band, they do show morphs.
Post edited by PulpArtst on
  • Richard HaseltineRichard Haseltine Posts: 111,715
    Not all morphs will appear in the Shaping pane, check the Parameters pane which should show everything. I think Lollipop hair is a figure, in which case check to see if the morphs are on the neck bone.
  • PulpArtstPulpArtst Posts: 88
    edited August 2014
    I got it to work but I had to first apply the "00 Morphs INJ". Thanks. You were right, they were under the "neck".
