Vascularity HD for Genesis not working (Problem Solved)
K T OngK T Ong Posts: 486
edited August 2014 in The Commons
Recently bought Vascularity HD for Genesis (http://www.daz3d.com/new-releases/vascularity-hd-for-genesis). Installed it (manually) and tried it on my Genesis figures. (I selected my Genesis figure in the scene, went to 'Parameters' ---> 'Actor' and tried out some of the vascularity morphs.) I saw nothing at all when I rendered the scene.
I figured maybe I needed to start with a fresh Genesis figure. So I tried that. Still nothing at all.
Tried finding a 'Readme' in what I bought which would explain how I should use the thing. Nothing.
Help, please? Thanks. (For DAZ Studio I used Version 4.6.0.18 Pro Edition (64-bit), in case that's got anything to do with it.)
Post edited by K T Ong on
  • nightwolf1982nightwolf1982 Posts: 1,320
    Might try re-installing the morphs, make sure they're installed to the same place as Genesis. There really isn't a whole lot to using them, just dial the morphs to whatever strength you prefer.
    Also, make sure you're using the correct version - the morphs you posted are for the Genesis 1 figure, there's a separate set for the Genesis 2 figures.
  • Richard HaseltineRichard Haseltine Posts: 111,348
    I'm pretty sure you need to update DS - 4.6.0.18 is quite old now and may well pre-date HD morphs (even if it doesn't I seem to recall it had a couple of nuisance bugs).
  • Zev0Zev0 Posts: 7,123
    edited August 2014
    Richard, Hellboy is having the same issue. http://www.daz3d.com/forums/discussion/44298/P45/ Can you ask Daz to see if there is indeed a problem? Could be the installer. I tried the manual install for G1 version and it worked..Have not tested the Dim version.
    Post edited by Zev0 on
  • K T OngK T Ong Posts: 486
    At least I now know I'm not the only one. ;-)
    Guess I'll just have to go through the trouble of updating my version of DAZ Studio, just to see if it goes well this time...
    edited August 2014
    Try the manual download of the product and tell me if the problem remains. I don't really use Dim so I cant test that version. My content is set up for manual installs only because my paths are all custom.
    Manual install works for both - http://www.daz3d.com/forums/viewreply/658813/
    Ok tested Dim version and that works as well.
    edited August 2014
    Upgraded DAZ Studio to 4.6.3.52, uninstalled and re-installed Vascularity HD for Genesis. Yup, it worked this time! :-) Thanks for the help, fellas!
    All the trouble one has to go through to make something work...
    960 x 1280 - 1M
    edited August 2014
    Cool. Glad you got it working:) Can you change thread title please to Got it working or solved lol. As it is many people will think its broken just by seeing the title. Thanks :lol:
    Okay, done! ;-)
    edited August 2014
    Thanks:) :-)
  • SaponiSaponi Posts: 11
    I bought Vasularity HD for Gen 2 to use on my 32 bit Win7 system not reading any of the threads before the purchase. It will not work with my current setup. I purchased the app back in October so I know I am out of luck as far as returning. I am hard headed and kept trying to get it to work. It would be helpful for others if a disclaimer is added to the Store front, saying it is designed for 64 bit systems. had I known ahead of time, I never would have purchased it. It is a great product and I am sorry that I cannot enjoy it. I did however, purchase Add Some Veins and it works great with my system.
