Can't make Zbrush work
jonas_haag9jonas_haag9 Posts: 0
Hi all!
Im new here and have just installed Daz4. The program runs great but when i want to send genesis model to Zbrush it cant find it.
I have installed Goz, is this a common problem for newbies?
Thankful for answer
Regards
  • Richard HaseltineRichard Haseltine Posts: 111,965
    Did you have the demo version of ZBrush installed before installing the full version? Or the full version installed to a different folder before its current folder?
  • frank0314frank0314 Posts: 15,116
    I'm not 100% positive but I believe the option in the File menu. You should see something at the bottom "send to zBrush"
  • foleyprofoleypro Posts: 485
    The GoZ plugin from daz needs to go into the pixologic folder...
    1280 x 1024 - 94K
    Then the icon will appear in the UI if you are useing the city limits interface option...
    1280 x 1024 - 164K
  • jonas_haag9jonas_haag9 Posts: 0
    Thank you all for fast response.
    I have checked everything you have written. And all seams right to me. But when i want to send genesis to Zbrush I press the "send to Zbrush" button and this window comes up ( Unable to connect with Pixologic Zbrush, check installation.) I have it installed so i dont understand?
    I installed the full Daz studio and then Goz.
    Thanks again
    Regards
    Jonas
    Have you tried reinstalling goZ just in case you accidentally pointed it to the wrong file.
    Yes i have, when i open the files it looks precisly like foleypro's attached picture.....
    I must have misunderstood a little bit here ... I thought Zbrush was part of the Das Studio program. No wonder why I do not get it to work because I dont have Zbrush, I only have Gozbrush. Im truly a newbie =P Apologies.
    No need to apologize. An honest mistake.
