Genesis Morphs do not work
msolomonmsolomon Posts: 213
Hello all I am having Genesis issues. The Evolution morphs will not load in Carrara. The add folder command will ad a folder but the morphs don't work on the Genesis.
My system is i7 Imac, 16 gig ram, 10.7 (Lion)
  • BrianP21361BrianP21361 Posts: 816
    I'm able to use the Evolution morphs for Genesis in Carrara. I'm also on a Mac, but I'm running Maverick's. I did have a lot of issues with Genesis content until a created a library exclusively for Genesis products and use DIM for installing. Now most things seem to work OK. How are you installing the morphs?
  • msolomonmsolomon Posts: 213
    I was using the DIM
  • DustRiderDustRider Posts: 2,911
    The Evolution Moprhs should show up in the parameter tab when you select either the figure, or the actor (see attached images., Sorry, I don't remember which one they can be found in. They won't be identified as being from a specific morph package, but as long as you are installing them to the proper location (where Genesis is installed, and DIM should have taken care of that for you), they should be available in the parameters tab. Unlike V4, M4, etc., you don't inject the morphs after loadeing the figure, they are always there once installed properly.
    Hope this all made sense and helped a bit.
    240 x 478 - 36K
    254 x 484 - 39K
    Right. No need to add a separate folder for morphs. Once Genesis (1 or 2) morphs are installed properly, they reside as a slider within Genesis - no INJecting is required! ;)
    edited August 2014
    just Loaded it, using DIM and selected actor, no evolution morphs were there.
    Post edited by msolomon on
    Hmm, I'm not sure where to point you to now, other than to check to see if Genesis and the evolution morphs are being installed to the proper location (unfortunately I use a PC, so can't help much here). If you look at your installed content in DIM, you can click on the arrow/triangle icon on the far right and select "installed files" to see where they are being installed.
    Just happened to think, are they working/showing in DS?
    The Genesis figure and the morphs all have to be installed in the same place. Make sure you load a new figure after installing the morphs. They won't load in a figure that was brought into Carrara prior to loading the morphs. Also I've seen some differences between which Genesis figure I load and the morphs available. I think there are three available in Carrara for me, Genesis base, Genesis female and Genesis male.
    Problem solved! I had to delete the default option in the DIM preferences and choose the location all the other content was being placed. Now the morphs show up.
    Thanks for all the help guys!
  • arcadyarcady Posts: 340
    Go back to the place your default location was installing things, and make sure there is nothing there - move that directory out of the way - or anything in it could randomly crash your carrara if it or items for it also end up installed somewhere else as well later on.
    Good idea, thanks.
