Eye Rip Issue: Default Genesis 8 Female
jbarooshjbaroosh Posts: 35
Hello Everyone,
I'm having trouble with the eyes of Genesis 8 female. I've noticed that at some angles the eyes have black "rips" in them when I render. The strange thing is that in the preview the eyes sometimes look fine but then when I render the black rips occur. This is without any morphs being used on the default Genesis 8 female figure. Any idea why this is happening? Would reinstalling the Genesis 8 female help? I think this bug mostly happens when the eyes are looking to a side instead of straight ahead.
I tested this with Genesis 8 male and didn't have any problems.
Thanks in advance for your help!
Edit: This bug only happens when the eyes are looking to the left side. If you take the Eyes Side-Side slider and put it at -100% you might be able to replicate the issue. If you're able to replicate how do you fix it?
536 x 756 - 630K
Post edited by jbaroosh on
  • barbultbarbult Posts: 27,518
    This often happens under two conditions with Iray:
    1. You have moved the character far from 0,0,0 world center. Move the character back to 0,0,0 and move your environment/set instead of the character.
    2. You are rendering with Instance Optimization set to Memory, which is necessary for scenes with a large number of instances. If your scene doesn't use instances and you are using Instance Optimization value of Memory, change it to Speed. This setting is on Render Settings.
  • jbarooshjbaroosh Posts: 35
    edited November 2020
    Setting the Instancing Optimization to Speed fixed the issue. Before it was on Auto. Thanks so much!
