"HeroFX Alchemy and MagicFX" and "Hero FX Exp Magic 2" how to use
I'm relatively new to using DAZStudio and purchased the above products. Is there some procedure to follow to use the products? I tried clicking them are being told to select and object and received no results. If anyone could help me my name is
John Caruso and my email is:
[email protected].  Any help would be gretly appreciated.
John Caruso
  • NorthOf45NorthOf45 Posts: 5,915
    Don't worry, you'll get replies here, but I would remove any personal info from your post, as it could go places you don't want.
    First, load the "FX-planeM.cr2" figure from "HeroFX Alchemy and MagicFX" and then apply the material poses from either product, usually a transparency map and a colour map. Select the Base node in the scene tab to get access to the morphs in the Parameters tab.
