Genesis 2 male/genesis -no poser contoler
Hi
When I first installed daz 3d, I had the possibility to add a male character different facial expressions (fear, satisfaction, laughter ect). Now when reinstalled, I do not have these options.
They feature is available only for Genesis 2 female.
Is something not installed, or installed wrong?
Post edited by calaopie on
Select G2M 'Head' in the Scene Pane, and you should find them in Pose Controls > Head > Expressions.
These will only show with the Head selected. Did you install using DIM (DAZ Install Manager), or manually?
That's what I'm saying. Panel expression is not there.
Most I installed by DIM. Only a few installed manually but have no connection with the G2M
Genesis 2 Male is part of the Genesis 2 Starter Essentials bundle. In DIM you will find it under 'Genesis 2 Male Starter Essential'. If these morphs are not showing up, then you may need to reinstall it again. Check in DIM to make sure that it has been installed correctly.
Is this a new figure that you have just loaded, or is it a saved scene?
I load him in saved scen (for example) .
Please try this by loading a new Genesis 2 Male figure, and see if the morphs appear then?
It may be a problem with you directories in the Content Directory Manager (Edit > Preferences > Content Library > Content Directory Manager). They may not be set up correctly.
Did you have the Scene saved in your 'My DAZ 3D Library' folder, or somewhere else?
Still not working, but the "dragon sayler" has already have pose controls .
edit: I manually installed Genesis Starter Esentiale in my folder content and finally work.
Thanks for help ;)
OK, I am glad it is working for you now.
