Bryce 6.3 Default ground plane
Is there a way to permanently change the default material to flat gray ???
Cheers
GG
  • HoroHoro Posts: 11,739
    edited October 2020
    No kiwi_gg, this is not possible. What you can do is giving it the desired material (set the sky as you wish, image size, etc) and save that scene as [default.br6] (without the brackets) into the location where the Bryce.exe file resides - and overwrite the existing. Each time you start Bryce, default.br6 is loaded. I hope it helps.
    Post edited by Horo on
  • kiwi_ggkiwi_gg Posts: 198
    Thanks Horo.
    Cheers
    GG
