Victorian bedroom preload
WendyLuvsCatz
in The Commons
am I overlooking it or is there a preload somewhere for the LS Victorian bedroom furniture with the various sets and materials?
I have the various Vanity Reflections etc materials but it is all over the place with the bedroom in environments and furniture in props
the most I can find is a preload for the bits for the vanity table and if you load the bed and it's pillows at zero you can parent them
I cannot say I like any of my own furniture arrangements in the room
Huh, I could have sworn there was. However, there is one scene preload in the add-on Gracious Preparations Poses.
mmm I may need to grab that
Thx
Just checked, and I think that's all the preloads that come with it. Here's one I did. It's a pretty heavy set if you don't reduce the oodles of 4k textures that come with it.
thankyou Sevrin
it's not that I was lazy BTW I just disliked every way I moved the furniture
I was hoping the promo ones existed
also I will use Filament
got a lot of blocks I swapped with the furnitures of the same name
and I think I figured out the issue
I have all the bits Reflections furniture and room but not Reflections 1 iray
it seems it won't substitute the originals but at least I know where they go
I do have
https://www.daz3d.com/reflections-furniture-iray
https://www.daz3d.com/reflections-room-iray
but not
https://www.daz3d.com/reflections1-iray
which is the desk, Vanity and a few bits I have but not iray
it's so confusing, I have all the texture addons apparently just not that one set
which is all the stuffs I have remapped and remodelled apparently
Do you have the current updated versions of all the addons, and especially the base prop sets? That used to regularly cause problems back when DAZ started the whole thing of issuing D|S native format updates to Poser-era oldies-but-goodies.
I think Sevrin used the iray version that has new geometry hence the blocks
I neglected to mention some of mine were the 3Delight and Poser versions because I overlooked the fact the geometry had been updated too.
I am missing just this one but do have it's old DAZ/Poser 3Delight ones
(will try and grab it before PC+ runs out, have a few things I will use next month's 6 off 18 coupon on.before I go)
Most sets its textures and shaders only so you wouldn't get blocks just missing maps.
Thing is the textures I want to use are not set up for iray anyway.
I like the Symphony ones.
