viewing interactve tutorial problem
I am unable to view the "continue" or "escape" button on interactive tutorials. The buttons are below the level of the screen. I read a previous post which said a workround was to rotate display then return to landscape but I cannot do this on my computer. Does anyone have any suggestions?
What is your screen resolution set to?
Can you change it so that you can see all of the windows that pop up?
Screen res is 1366 x 768. I can change the 1366 but not the 768
Did you see this post from DAZ_Jared? There is a problem on some older monitors where the resolution cannot be changed, and we are waiting for a fix.
1366 x 768 is the same resolution as my computer. Had to hide the task bar to use buttons on SciFi tut. And if anyone from DAZ is still listening part of the problem is the location of the dialogue box, it pops in with its top about a quarter of way down the screen.
I have a problem with the tutorials also...the tutorial is right i the middle of my screen so I can't see the DS window to see what is actually happening as I go through the tutorial. I have tried to move the window over but it won't , is there a trick to this I am not aware of?
