iMac and MacBook Pro contents not the same
iSeeThisiSeeThis Posts: 560
I've installed 488 items into my iMac and MacBook Pro equally. But there are something weirdly different. When I select V4 on iMac, Smart Content shows End of Summer Hair. But when I do it on MacBook Pro, there is no End of Summer Hair to pick up. There must be something wrong. I've reimport metadata but nothing changes. Please help.,
1500 x 900 - 790K
  • fixmypcmikefixmypcmike Posts: 19,730
    Are both using the same version of DS and the same package for the product as well as for V4? Are you loading V4 the same way on both (e.g. from the Victoria 4.2.cr2)?
    On my system I'm not seeing it listed when V4 is loaded, only the Genesis version when Genesis is loaded.
  • iSeeThisiSeeThis Posts: 560
    Thank you, fixmypcmike. I'm quite sure that everything is the same. But I will check something relating with versions as you suggest.
