Urban Sprawl 2 or 3? Or neither?
DefaultNameDefaultName Posts: 441
edited October 2020 in Art Studio
Hello. I'm interested in buying https://www.daz3d.com/urban-sprawl-3 or https://www.daz3d.com/urban-sprawl-2-the-big-city since they're on sale, but can really only budget one.
I'm wanting them because I want a city environment for scenes, I don't really have buildings/skyscrapers that all fit nicely like that. Also, do they scale for normal Daz characters? I own another item "Dystopia city blocks", that starts extremely small, and I can't scale it properly.
I'm leaning towards 3, because the models seem noticeably newer, and from the promos, it looks like you can make different pre-made city arrangements, some more like a CBD, others more like a smaller city, unlike 2, which only seems to be the one city.
I did want to make sure I wasn't overlooking something, would definitely appreciate feedback from anyone who owns either of these, and I'd appreciate advice if you think there's a better Stonemason product for what I'm after (there's a lot!), or a different product/vendor altogether. Thank you!
  • LeanaLeana Posts: 13,612
    Both Urban Sprawl 2 and 3 are scaled to use with Daz characters.
    3 is indeed more recent. It includes Iray materials and lights, so if you plan to render with Iray that can save you time.
    Both are provided as either a complete city, as city blocks you can rearrange, or as individual props.
    Great thanks for the info! Sounds like 3 is the winner, because I do use Iray, and that is important to me.
    You can also use Urban Sprawl 2 with Iray, but that will mean a bit more work.
  • FirstBastionFirstBastion Posts: 8,076
    Urban sprawl 3's blocks fit together nicely.  Urban Sprawl 2 has NewZealand and British road setup.(Drive on left side)
  • Urban sprawl 3's blocks fit together nicely.  Urban Sprawl 2 has NewZealand and British road setup.(Drive on left side)
    Good to know! I bought 3 yesterday :) Still need to take it for a test spin
    I can recommend driving around with the Lamborghini lookalike thats on sale ;)
  • Moved to Art Studio as it is a question about wexisting products, not a Product Suggestion.
  • nonesuch00nonesuch00 Posts: 18,878
    I have both and Urban Sprawl 2 converts easily enough to iRay. I like Urban Sprawl 3 better though and unfortunately the scale and street layout doesn't quite allow for 100% alignment of Urban Spawl 2 & Urban Sprawl 3 if you use them in the same scene. You can make small adjustments and get them to work together though.
  • jjoynerjjoyner Posts: 873
    edited March 4
    I just bought Urban Sprawl 3 yesterday.  The five blocks in it all load at the 0-0-0 position.  Any advice on positioning the blocks so that they align edge to edge?
    @Stonemason
    Post edited by jjoyner on
  • Richard HaseltineRichard Haseltine Posts: 111,792
    The required offset seems to be about 9557.50, left-right or back-forward, and the roads line up so just arrange them as suits you (or build your own blocks out of a road base and whatever buildings you fancy).
  • NorthOf45NorthOf45 Posts: 5,915
    @Stonemason
    Try the Align tab, with the Stack option (on X and/or Z, zero spacing) with two or more base blocks selected. All the buildings will follow.
    NorthOf45 said:
    @Stonemason
    Which makes the offset 9558.180 cm (which is probably a nice round number in Poser units - possibly 40, allowing for imprecision in my conversion to Imperial units)
    edited March 5
    @NorthOf45 and @Richard Haseltine,
    Thanks for both of your suggestions. I hadn’t thought of the Align tool.
    Maybe @Stonemason will drop by as well.
  • StonemasonStonemason Posts: 1,260
    I think Richards suggestion should work, I just eyeball it, i didn't design it to snap to any particular number, Also you should be able to rotate each block in 90 degree increments and the roads will line up
    Thanks for stopping by!  I initially played with eyeballing the alignment as well before I posted my question.  Between that, Richard’s values, and using the Align tool, I think I’ll be OK.  Thanks for your body of 3D work.  I just bought four more of them on Tuesday; I’ve got 46 now.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,696
    you can also use https://www.daz3d.com/instances-plus-for-daz-studio to create a big city
    Thanks.  If I don't like the way the other suggestions work out, I might be able to find sometime already in my library that can come in handy.  Perhaps the Move Tool in the Code 66 Toolbox - Volume 1 (https://www.daz3d.com/code-66-toolbox--volume-1).
