Save Scene Subset with Animation?
DekeDeke Posts: 1,636
I'm trying to save a group of walking people so I can drop them into different scenes. I saved as a Scene Subset and imported it…worked find, but the walking animation isn't there (though a lot of key frames are). Is there some added trick to saving a scene subset with animation?
    I don't do animations usually, but I would think that saving as a 'Scene' should save the Animation as well? You can delete any cameras or lights, or any other objects that you don't want, then save it under a different name.
    You can then Merge the Scene into any other Scene, in the same way as a Scene Subset.
    Failing that, saving as an Aniblock would be the best way to do it, that is what they are for, but you need the full version of Animate 2 as far as I know.
