Download failed in DIM and through browser
Could someone fix this as I can't download products. Install manager and tried zip as well from browser
1704 x 811 - 60K
  • tsroemitsroemi Posts: 3,668
    Some downloads are failing for me as well - "Frost for Winter Fantasy" and "SY Templates for Genesis 3 Male" both don't work. Please fix, thanks!
  • HaruchaiHaruchai Posts: 2,040
    Seems to a common problem at the moment. I'm sure someone else with more knowledge will post but my experience is to keep trying. I just keep hitting the download button and all mine have, eventually, installed. One got really stuck and I found a partial download file in my download location so I deleted it and it installed after that.
  • I had the same issues yesterday, and opened a ticket. The response was that they do have network errors and are working hard to fix them. In my case, the issue was solved about an hour later.
    So, wait a bit, then retry. If the error persists for a longer period, I would suggest opening a ticket.
  • KerwinKerwin Posts: 124
    I ended up opening a ticket.   About a dozen other files have downloaded.   Just one product seems to not download via DIM or the browser.
  • 3Diva3Diva Posts: 12,058
    edited October 2020
    Richard said that he's told that Daz is aware of it and are looking into it: https://www.daz3d.com/forums/discussion/comment/6143491/#Comment_6143491
    Post edited by 3Diva on
  • Justin_AmesJustin_Ames Posts: 185
    2022 and still happening with every single one of my files.. are you sure Daz worked on that problem back in 2020? ^^'
  • felisfelis Posts: 6,642
    I think you need to be more specific.
    How are you installing, and what is your experience.
    I have had faulty products, but can't remember any general failure with installations.
    Fixing a network/server issue once doesn't mean it will never ever have a problem again - especially within 2 years.
    It doesn't mean much but I have downloaded plenty of stuff via DIM over the past month or so - including last night which was about 5/6 hours before your post. The only time I had any failures was when my own internet was being a bit rubbish and they worked the second time when I restarted.
  • SevrinSevrin Posts: 6,314
    The thing in 2020 was a CDN issue, not a DIM issue.  If downloads are failing, it's because of a screwed up installation, or firewall/permissions block, or insufficient disk space or some other local issue.
