Transparency issues in older DS version
grylingrylin Posts: 278
edited August 2014 in Daz Studio Discussion
are ther any ways to work around this? i am using ds 2.3 for some older scenes which work fine, but the characters are transparent! no matter what i try... could it be because of my laptop?
i have windows 8.1
1366 x 768 - 401K
Post edited by grylin on
    edited August 2014
    Does it render transparent? If not, then it is probably an OpenGL issue with your graphics card (or chip)
    I take it you have looked under the Surfaces pane to see what Opacity is set to?
    Edited to correct the first line.
    Post edited by JimmyC_2009 on
  • grylingrylin Posts: 278
    it renders quite fine, no issues there :) and i hav tried everyithing else
    Some laptops have very poor graphics chips, but you may be able to find a newer driver for OpenGL that would fix it.
    That's all I can think of for the moment.
    thanyou for the advice. i will see if i can do that
    it seems that my intel, will not update. my drivers... and i have tried so many ways of making it work... i like ds 2.3 because its not as complicated and i can make my 3d characters with ease on it too.
    ANY other advide is so much appreciated right now, i have even made a fresh install . all my other Daz studios, 3 and 4.5, 4.6. are working just fine
    these are my settings for the videocard:
    1366 x 768 - 83K
    It looks to me like the OpenGL version is too 'new' for DS2, and that may be the problem.
    In that case, the only solution would be an older driver from a few years back (if one exists), but I don't think there would be any way to get it to work with DS2 as it is now.
    Someone else may see this thread and offer some suggestions, I don't even have DS2 installed any more so I can't help at all, sorry.
    maybe i could try to downgrade it . i am googling this :P
    am not giving up just yet
  • fixmypcmikefixmypcmike Posts: 19,741
    Yes, I've seen this before, and it seems to be OpenGL drivers that are too new for DS2.3 to use correctly.
