Stop[Esc] and Continue buttons not showing for Sci-fi was Lesson
Good day ALL,
I need your help around this. The Stop [Esc] and Continue buttons are not showing for interactive lessons of the Sci-fi warrior bundle I just downloaded. I have tried re-sizing windows and the later hiding the task-bar but it doesn't seem to help reveal the buttons. Please help out here. Thanks a loaded bunch in anticipation of your help around this.
What is your Screen Resolution set to, that may be the problem? Does it work with other interactive lessons? Can you please post a screenshot of what you are seeing, and give a little more information on the machine you are using?
I can see both of these buttons at the bottom of the window.
The issues with the SciFi-Warrior Lesson have been discussed here:
http://www.daz3d.com/forums/discussion/41659/P15/#618767
See Post #29 by DAZ_Jared:
The box draws at a fixed height. That particular box's height is 415 pixels. This means that if you don't have at least 415 pixels from the top of your screen to the bottom it is going to get cut off.
Standard monitor resolution for most modern monitors is 1920x1080 so there is plenty of room. Older monitors may still have a problem. Especially if you have your task bar showing which takes up more precious real estate.
We are working on updates to those interactive lessons so that they run better in DAZ Studio 4.6.3+. We are also going to re-size the images so that they don't take up as much space.
From your screen shot it appears that if you hide your task bar there will be enough room for you to see the "Continue" and "Stop [esc]" buttons at the bottom of the window.
