Genesis (1) Loading Errors and Shaping Issues
SLoTH_XVXSLoTH_XVX Posts: 199
I am getting an error when I load Genesis(1) figure into my scenes using Studio 4.6.3.50 Pro.
Below is a screen of the message I get every time I load a Genesis figure into a scene of any kind. And once it is loaded not all the shaping options or morphs work properly. Some work while others only morph the head and others turn the figure into cottage cheese. Is there supposed to be a base texture that loads onto Genesis by default, because when I load Genesis into a scene it loads without any textures at all.
Here is a copy of the log file created when I load the figure:
+++++++++++++++ DAZ Studio 4.6.3.50 starting +++++++++++++++++
Platform bits: 64
Qt Version: 4.8.6
OpenSubdiv Version: 2.3.5
Running on Windows 7, Build 7601, Service Pack 1
CPU Information:
CPU String: GenuineIntel
CPU Brand String: Intel(R) Core(TM) i7-4820K CPU @ 3.70GHz
Cache Line Size = 64
L2 Associativity = 6
Cache Size = 256
Stepping ID = 4
Model = 14
Family = 6
Extended model = 3
CLFLUSH cache line size = 64
Supported CPU Features:
SSE3 New Instructions
MONITOR/MWAIT
CPL Qualified Debug Store
Thermal Monitor 2
x87 FPU On Chip
Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
APIC On Chip
SYSENTER and SYSEXIT
Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
Page Attribute Table
Page Size Extension
CFLUSH Extension
Debug Store
Thermal Monitor and Clock Ctrl
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Self Snoop
Hyper-threading Technology
Thermal Monitor
Pend. Brk. EN.
Physical Memory:
Total: 15.9 GB (17097375744)
Avail: 12.8 GB (13767798784)
Virtual Memory:
Total: 7.9 TB (8796092891136)
Avail: 7.9 TB (8795878064128)
Current Memory Usage: 19%
Current DateTime:
Loc: Sun Jul 27 22:01:20 2014
UTC: Mon Jul 28 03:01:20 2014
Temp Data:
Location = C:/Users/KMcBriarty/AppData/Roaming/DAZ 3D/Studio4/temp
Disk Total: 117.2 GB (125927682048)
Disk Avail: 13.4 GB (14491930624)
Locale: en_US
No translator found.
Reading style definition C:/Program Files/DAZ 3D/DAZStudio4/resources/style/Darkside.style
Creating managers
Reading help index
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/EXPExporter/ExPExporter.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/FBXExporter/FBXExporter.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/FigureSetup/FigureSetup.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/JointEditor/JointEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/LAMH Player/LAMH Player.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/LayeredImageEditor/LayeredImageEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/MorphLoader/MorphLoader.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/MorphLoaderPro/MorphLoaderPro.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/PolygonGroupEditor/PolygonGroupEditor.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/TextureAtlas/TextureAtlas.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/Plugins/WeightMapBrush/WeightMapBrush.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/inlinehelp.dsx
Scanning import folders
Scanning content folders
Using GLEW 1.9.0
Supported OpenGL extensions:
GL_AMD_multi_draw_indirect
GL_AMD_seamless_cubemap_per_texture
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_bindless_texture : NOT INITIALIZED
GL_ARB_blend_func_extended
GL_ARB_buffer_storage : NOT INITIALIZED
GL_ARB_clear_buffer_object
GL_ARB_clear_texture : NOT INITIALIZED
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_compute_shader
GL_ARB_compute_variable_group_size : NOT INITIALIZED
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_indirect
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_instanced
GL_ARB_enhanced_layouts : NOT INITIALIZED
GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_indirect_parameters : NOT INITIALIZED
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_bind : NOT INITIALIZED
GL_ARB_multi_draw_indirect
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_robust_buffer_access_behavior
GL_ARB_robustness
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_seamless_cubemap_per_texture : NOT INITIALIZED
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_bit_encoding
GL_ARB_shader_draw_parameters : NOT INITIALIZED
GL_ARB_shader_group_vote : NOT INITIALIZED
GL_ARB_shader_image_load_store
GL_ARB_shader_image_size
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_query_buffer_object : NOT INITIALIZED
GL_ARB_shader_storage_buffer_object
GL_ARB_shader_subroutine
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_include
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_mirror_clamp_to_edge : NOT INITIALIZED
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_stencil8 : NOT INITIALIZED
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev : NOT INITIALIZED
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_S3_s3tc
GL_EXT_texture_env_add
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_Cg_shader
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXTX_framebuffer_mixed_formats : NOT INITIALIZED
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_shader_objects
GL_EXT_separate_specular_color
GL_EXT_shader_integer_mix : NOT INITIALIZED
GL_EXT_shader_image_load_store
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod : NOT INITIALIZED
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_shared_exponent
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_storage : NOT INITIALIZED
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback2 : NOT INITIALIZED
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_EXT_vertex_attrib_64bit
GL_EXT_import_sync_object : NOT INITIALIZED
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KHR_debug
GL_KTX_buffer_region
GL_NV_bindless_multi_draw_indirect : NOT INITIALIZED
GL_NV_bindless_texture
GL_NV_blend_equation_advanced : NOT INITIALIZED
GL_NV_blend_square
GL_NV_compute_program5 : NOT INITIALIZED
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_draw_texture : NOT INITIALIZED
GL_NV_ES1_1_compatibility : NOT INITIALIZED
GL_NV_explicit_multisample
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragment_program
GL_NV_fragment_program_option
GL_NV_fragment_program2
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_gpu_program4
GL_NV_gpu_program4_1 : NOT INITIALIZED
GL_NV_gpu_program5
GL_NV_gpu_program5_mem_extended : NOT INITIALIZED
GL_NV_gpu_program_fp64
GL_NV_gpu_shader5
GL_NV_half_float : NOT INITIALIZED
GL_NV_light_max_exponent
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2
GL_NV_path_rendering
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_shader_atomic_counters : NOT INITIALIZED
GL_NV_shader_atomic_float
GL_NV_shader_buffer_load
GL_NV_shader_storage_buffer_object : NOT INITIALIZED
GL_ARB_sparse_texture : NOT INITIALIZED
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_expand_normal
GL_NV_texture_multisample
GL_NV_texture_rectangle
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_transform_feedback
GL_NV_transform_feedback2
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_attrib_integer_64bit
GL_NV_vertex_buffer_unified_memory
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_NVX_conditional_render : NOT INITIALIZED
GL_NVX_gpu_memory_info
GL_NVX_nvenc_interop : NOT INITIALIZED
GL_NV_shader_thread_group : NOT INITIALIZED
GL_NV_shader_thread_shuffle : NOT INITIALIZED
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_EXT_swap_control : NOT INITIALIZED
WGL_ARB_buffer_region
WGL_ARB_create_context
WGL_ARB_create_context_profile
WGL_ARB_create_context_robustness
WGL_ARB_extensions_string
WGL_ARB_make_current_read
WGL_ARB_multisample
WGL_ARB_pbuffer
WGL_ARB_pixel_format
WGL_ARB_pixel_format_float
WGL_ARB_render_texture
WGL_ATI_pixel_format_float
WGL_EXT_create_context_es_profile
WGL_EXT_create_context_es2_profile
WGL_EXT_extensions_string
WGL_EXT_framebuffer_sRGB
WGL_EXT_pixel_format_packed_float
WGL_EXT_swap_control_tear
WGL_NVX_DX_interop
WGL_NV_DX_interop
WGL_NV_DX_interop2
WGL_NV_delay_before_swap
WGL_NV_float_buffer
WGL_NV_multisample_coverage
WGL_NV_render_depth_texture
WGL_NV_render_texture_rectangle
: NOT INITIALIZED
OpenGL features for current hardware:
OpenGL provider: NVIDIA Corporation
OpenGL renderer: GeForce GTX 780/PCIe/SSE2
OpenGL version: 4.4.0
Maximum number of lights: 8
Number of auxiliary buffers: 4
Number of texture units: 4
Depth buffer bit resolution: 24
Maximum OpenGL texture size: 16384 x 16384
Current OpenGL Texture Quality Setting: Good Performance
RGBA color bitplane resolutions: 8 8 8 0
GLSL version: 4.40 NVIDIA via Cg compiler
Shadow mapping supported
VBO supported
Connected to CMS: 4.8
*** Scene Cleared ***
Loading plug-ins:
aniMate2.dll
d3dGenX2.dll
dazscriptide.dll
dz3dconnexion.dll
dz3dmouse.dll
dzalignace.dll
dzassetiofilters.dll
dzautofit.dll
dzautoriggerbasic.dll
dzautoshaderbakeractions.dll
dzbrycebridge.dll
dzbvh.dll
dzcolladax.dll
dzcomponents.dll
dzcontentdbeditor.dll
dzcontentlibrarypane.dll
dzcr2exporter.dll
dzcustomizedlg.dll
dzdelightrenderer.dll
dzdformeditor.dll
dzeasyloader.dll
dzexpexporter.dll
dzfbxexporter.dll
dzfbximporter.dll
dzfiguresetup.dll
dzhexagonbridge.dll
dzimageio.dll
dzjointeditor.dll
dzlayerededitor.dll
dzlayerfilter.dll
dzmanualshaderbaker.dll
dzmaptransfer.dll
dzmorphfollower.dll
dzmorphloader.dll
dzmorphloaderpro.dll
dzobjexporter.dll
dzoptitexclothbasic.dll
dzpolygongroupeditortool.dll
dzprimitives.dll
dzpropertyhierarchyeditor.dll
dzpuppeteer.dll
dzpz3importer.dll
dzrenderedit.dll
dzrenderlibrary.dll
dzrslshadercompiler.dll
dzsavefilters.dll
dzscriptedrenderer.dll
dzscriptedsteps.dll
dzshaderbaker.dll
dzshaderbuilder.dll
dzshadereditor.dll
dzshadermixerbase.dll
dzshadermixergui.dll
dzsmartcontentpane.dll
dzspotrendertool.dll
dztextureatlas.dll
dztransferutility.dll
dzu3dexporter.dll
dzweightmapbrush.dll
dzwinvideo.dll
lamhPlayerPlugin.64.dll
Luxus.dll
sdk_sceneinfopane.dll
dzdrawstyles.dll
dzpowerpose.dll
Reality_2.0.dll
DEBUG: initDB!
DEBUG: Db is Open
Error writing author data!
Total class factories: 1332
WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
3D mouse support library could not be loaded.
Creating interface
Successfully created OpenGL viewport for Viewport1.
Successfully created OpenGL viewport for Viewport2.
Successfully created OpenGL viewport for Viewport3.
Successfully created OpenGL viewport for Viewport4.
WARNING: QFile::flush: No file engine. Is IODevice open?
WARNING: Could not parse stylesheet of widget 0xba59440
Executing startup script...
DEBUG: Updating the ACSEL database with adjustments for the bumpMapStrength value
Started in: C:/Program Files/DAZ 3D/DAZStudio4
DAZ Studio Started
Creating Pixel Buffer
Pixel buffer - Width: 1024 Height: 1024
Compiling OpenGL Shader...
Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Shader Program successfully linked.
WARNING: Object::disconnect: Unexpected null parameter
WARNING: QCoreApplication::postEvent: Unexpected null receiver
DEBUG: End DAZ Studio to Hexagon Bridge log...
--------------- DAZ Studio 4.6.3.50 exited ------------------
Platform bits: 64
Qt Version: 4.8.6
CPU Information:
Cache Size = 256
Stepping ID = 4
Model = 14
Family = 6
Extended model = 3
MONITOR/MWAIT
Thermal Monitor 2
x87 FPU On Chip
Time Stamp Counter
APIC On Chip
PTE Global Bit
Page Size Extension
CFLUSH Extension
Debug Store
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Self Snoop
Thermal Monitor
Pend. Brk. EN.
Physical Memory:
Avail: 12.8 GB (13813350400)
Virtual Memory:
Current DateTime:
Loc: Mon Jul 28 20:09:31 2014
UTC: Tue Jul 29 01:09:31 2014
Temp Data:
Disk Avail: 13.3 GB (14317510656)
Locale: en_US
Creating managers
Reading help index
Using GLEW 1.9.0
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_clamp
GL_ARB_draw_buffers
GL_ARB_gpu_shader5
GL_ARB_imaging
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_point_sprite
GL_ARB_robustness
GL_ARB_shadow
GL_ARB_sync
GL_ARB_texture_rg
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_S3_s3tc
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_minmax
GL_EXT_Cg_shader
GL_EXT_fog_coord
GL_EXT_gpu_shader4
GL_EXT_packed_float
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_sRGB
GL_EXT_timer_query
GL_EXT_vertex_array
GL_KHR_debug
GL_NV_blend_square
GL_NV_copy_image
GL_NV_depth_clamp
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_gpu_program4
GL_NV_gpu_program5
GL_NV_gpu_shader5
GL_NV_point_sprite
GL_SGIS_texture_lod
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_ARB_multisample
WGL_ARB_pbuffer
WGL_NVX_DX_interop
WGL_NV_DX_interop
WGL_NV_DX_interop2
WGL_NV_float_buffer
: NOT INITIALIZED
VBO supported
Loading plug-ins:
aniMate2.dll
d3dGenX2.dll
dazscriptide.dll
dz3dconnexion.dll
dz3dmouse.dll
dzalignace.dll
dzautofit.dll
dzbrycebridge.dll
dzbvh.dll
dzcolladax.dll
dzcomponents.dll
dzcr2exporter.dll
dzcustomizedlg.dll
dzdformeditor.dll
dzeasyloader.dll
dzexpexporter.dll
dzfbxexporter.dll
dzfbximporter.dll
dzfiguresetup.dll
dzhexagonbridge.dll
dzimageio.dll
dzjointeditor.dll
dzlayerededitor.dll
dzlayerfilter.dll
dzmaptransfer.dll
dzmorphfollower.dll
dzmorphloader.dll
dzobjexporter.dll
dzprimitives.dll
dzpuppeteer.dll
dzpz3importer.dll
dzrenderedit.dll
dzrenderlibrary.dll
dzsavefilters.dll
dzscriptedsteps.dll
dzshaderbaker.dll
dzshaderbuilder.dll
dzshadereditor.dll
dztextureatlas.dll
dzu3dexporter.dll
dzwinvideo.dll
Luxus.dll
dzdrawstyles.dll
dzpowerpose.dll
Reality_2.0.dll
DEBUG: initDB!
DEBUG: Db is Open
Creating inte
518 x 118 - 21K
  • fixmypcmikefixmypcmike Posts: 19,741
    Can you post the end of the log file, from when you try to load Genesis?
    Genesis 1 loads untextured.
    You have the next-to-latest version of D|S (the current one is actually 4.6.3.52) but when did you last update your Genesis starter content? That hasn't changed for the last couple of program updates, but if your Genesis content is any older than that, you might be seeing Weird Stuff™ happening due to the program expecting updated files that aren't there.
  • SLoTH_XVXSLoTH_XVX Posts: 199
    Thanks for the replys Mike and Kitty.
    I installed latest Studio version and re-downloaded and re-installed all Genesis and Genesis2 Essential files and am still getting the same error message.
    Platform bits: 64
    Qt Version: 4.8.6
    CPU Information:
    Cache Size = 256
    Stepping ID = 4
    Model = 14
    Family = 6
    Extended model = 3
    APIC Physical ID = 4
    MONITOR/MWAIT
    Thermal Monitor 2
    x87 FPU On Chip
    Time Stamp Counter
    APIC On Chip
    PTE Global Bit
    Page Size Extension
    CFLUSH Extension
    Debug Store
    MMX Technology
    FXSAVE/FXRSTOR
    SSE Extensions
    SSE2 Extensions
    Self Snoop
    Thermal Monitor
    Pend. Brk. EN.
    Physical Memory:
    Avail: 13.2 GB (14205394944)
    Virtual Memory:
    Current Memory Usage: 16%
    Current DateTime:
    Loc: Thu Jul 31 21:07:51 2014
    UTC: Fri Aug 1 02:07:51 2014
    Temp Data:
    Disk Avail: 12.9 GB (13953986560)
    Locale: en_US
    Creating managers
    Reading help index
    Using GLEW 1.9.0
    GL_ARB_copy_buffer
    GL_ARB_copy_image
    GL_ARB_debug_output
    GL_ARB_depth_clamp
    GL_ARB_draw_buffers
    GL_ARB_gpu_shader5
    GL_ARB_imaging
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_point_sprite
    GL_ARB_robustness
    GL_ARB_shadow
    GL_ARB_sync
    GL_ARB_texture_rg
    GL_ARB_texture_view
    GL_ARB_timer_query
    GL_ARB_window_pos
    GL_ATI_draw_buffers
    GL_S3_s3tc
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_blend_color
    GL_EXT_blend_minmax
    GL_EXT_Cg_shader
    GL_EXT_fog_coord
    GL_EXT_gpu_shader4
    GL_EXT_packed_float
    GL_EXT_shadow_funcs
    GL_EXT_stencil_wrap
    GL_EXT_texture3D
    GL_EXT_texture_sRGB
    GL_EXT_timer_query
    GL_EXT_vertex_array
    GL_KHR_debug
    GL_NV_blend_square
    GL_NV_copy_image
    GL_NV_depth_clamp
    GL_NV_fence
    GL_NV_float_buffer
    GL_NV_fog_distance
    GL_NV_gpu_program4
    GL_NV_gpu_program5
    GL_NV_gpu_shader5
    GL_NV_point_sprite
    GL_SGIS_texture_lod
    GL_SGIX_shadow
    GL_SUN_slice_accum
    GL_WIN_swap_hint
    WGL_ARB_multisample
    WGL_ARB_pbuffer
    WGL_NVX_DX_interop
    WGL_NV_DX_interop
    WGL_NV_DX_interop2
    WGL_NV_float_buffer
    : NOT INITIALIZED
    VBO supported
    Loading plug-ins:
    aniMate2.dll
    d3dGenX2.dll
    dazscriptide.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzautofit.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzcr2exporter.dll
    dzcustomizedlg.dll
    dzdformeditor.dll
    dzeasyloader.dll
    dzexpexporter.dll
    dzfbxexporter.dll
    dzfbximporter.dll
    dzfiguresetup.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzjointeditor.dll
    dzlayerededitor.dll
    dzlayerfilter.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzmorphloader.dll
    dzobjexporter.dll
    dzprimitives.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzrenderedit.dll
    dzrenderlibrary.dll
    dzsavefilters.dll
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzshadereditor.dll
    dztextureatlas.dll
    dzu3dexporter.dll
    dzwinvideo.dll
    Luxus.dll
    dzdrawstyles.dll
    dzpowerpose.dll
    Reality_2.0.dll
    DEBUG: initDB!
    DEBUG: Db is Open
    Creating interface
    WARNING: Could not parse stylesheet of widget 0xcaa9710
    DAZ Studio Started
    Fragment Shader:
    Linking Shader:
    F:/My Library/data/DAZ 3D/Genesis/Base/Morphs/Artemis/Milania/._V4_Custom_Milania Elf Ears.dsf (1,1): Syntax error - expected '{' or '['
    F:/My Library/data/DAZ 3D/Genesis/Base/Morphs/Artemis/Milania/._V4_Custom_Milania.dsf (1,1): Syntax error - expected '{' or '['
    Duplicate id "Gwenyth" found in file "/data/DAZ 3D/Genesis/Base/Morphs/Silver/Gwenyth/Gwenyth.dsf"
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Aiko 5/FHMAiko5.dsf#FHMAiko5?value in file : /data/DAZ 3D/Genesis/Base/Morphs/Thorneworks/Wednesday/Wednesday.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Aiko 5/FBMAiko5.dsf#FBMAiko5?value in file : /data/DAZ 3D/Genesis/Base/Morphs/Thorneworks/Wednesday/Wednesday.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLDesire.dsf#CTRLDesire?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_Rex/MCM_RexDesire.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLFrown.dsf#CTRLFrown?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_Rex/MCMRex_Frown.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMScream.dsf#PHMScream?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_RatMan/MCM_RatScream.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Freak 5/FBMFreak5.dsf#FBMFreak5?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_Lycaon/Raw_Lycaon.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Creature Creator/PBMTwoToe.dsf#PBMTwoToe?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_GreyAlien/Raw_GreyAlien.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Creature Creator/PBMThreeFinger.dsf#PBMThreeFinger?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_GreyAlien/Raw_GreyAlien.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Freak 5/FBMFreak5.dsf#FBMFreak5?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_Frankenstein/Raw_Frankenstein.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMBodyBuilderDetails.dsf#FBMBodyBuilderDetails?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_Donovan/Raw_Donovan.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Freak 5/FBMFreak5SuperFreak.dsf#FBMFreak5SuperFreak?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_CWSabreCat/CW_MSabreCat.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Freak 5/FBMFreak5.dsf#FBMFreak5?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_CWLion/CW_MLion.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Freak 5/FBMFreak5.dsf#FBMFreak5?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_Bear/Raw_Bear.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMWristThickness.dsf#PBMWristThickness?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_Bear/Raw_Bear.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Creature Creator/PBMToenailsClaw.dsf#PBMToenailsClaw?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_Bear/Raw_Bear.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Creature Creator/PBMFingernailsClaw.dsf#PBMFingernailsClaw?value in file : /data/DAZ 3D/Genesis/Base/Morphs/RawArt/Raw_Bear/Raw_Bear.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSad.dsf#PHMSad?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/mcm_ribbit_sad.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMPain.dsf#PHMPain?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/mcm_ribbit_pain.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMHappy.dsf#PHMHappy?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/mcm_ribbit_happy.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFrown.dsf#PHMFrown?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/mcm_ribbit_frown.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFlirtingMasculineR.dsf#PHMFlirtingMasculineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/mcm_ribbit_flirtmascright.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFlirtingMasculineL.dsf#PHMFlirtingMasculineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/mcm_ribbit_flirtmascleft.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFlirtingFeminineR.dsf#PHMFlirtingFeminineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/mcm_ribbit_flirtfemright.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFlirtingFeminineL.dsf#PHMFlirtingFeminineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/mcm_ribbit_flirtfemleft.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Freak 5/FBMFreak5.dsf#FBMFreak5?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/MCM_Ribbit_F5.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMDisgust.dsf#PHMDisgust?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/mcm_ribbit_disgust.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMContempt.dsf#PHMContempt?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/mcm_ribbit_contempt.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMConfused.dsf#PHMConfused?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Ribbits/mcm_ribbit_confused.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSurprise.dsf#PHMSurprise?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_Turtle_Surprise.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSnarlRight.dsf#PHMSnarlRight?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_Turtle_SnarlRight.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSnarlLeft.dsf#PHMSnarlLeft?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_Turtle_SnarlLeft.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSmileB.dsf#PHMSmileB?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_Turtle_SmileB.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMScream.dsf#PHMScream?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_Turtle_Scream.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSad.dsf#PHMSad?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_Turtle_Sad.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMHappy.dsf#PHMHappy?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_Turtle_Happy.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMExcitement.dsf#PHMExcitement?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_Turtle_Excitement.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMContempt.dsf#PHMContempt?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_Turtle_Contempt.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMConfused.dsf#PHMConfused?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_Turtle_Confused.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMAfraid.dsf#PHMAfraid?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_Turtle_Afraid.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSurprise.dsf#PHMSurprise?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_Mole_Surpise.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSnarlRight.dsf#PHMSnarlRight?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_Mole_SnarlRight.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSnarlLeft.dsf#PHMSnarlLeft?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_Mole_SnarlLeft.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMScream.dsf#PHMScream?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_Mole_Scream.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSad.dsf#PHMSad?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_Mole_Sad.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMHappy.dsf#PHMHappy?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_Mole_Happy.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFrown.dsf#PHMFrown?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_Mole_Frown.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMDisgust.dsf#PHMDisgust?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_Mole_Disgust.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMConfused.dsf#PHMConfused?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_Mole_Confused.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMAfraid.dsf#PHMAfraid?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_Mole_Afraid.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSurprise.dsf#PHMSurprise?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_Surprise.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMScream.dsf#PHMScream?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_Scream.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMSad.dsf#PHMSad?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_Sad.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMPain.dsf#PHMPain?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_Pain.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMHappy.dsf#PHMHappy?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_Happy.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFrown.dsf#PHMFrown?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_Frown.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFlirtingMasculineR.dsf#PHMFlirtingMasculineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_FlirtMascRight.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFlirtingMasculineL.dsf#PHMFlirtingMasculineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_FlirtMascLeft.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFlirtingFeminineR.dsf#PHMFlirtingFeminineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_FlirtFemRight.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFlirtingFeminineL.dsf#PHMFlirtingFeminineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_FlirtFemLeft.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMExcitement.dsf#PHMExcitement?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_Excitement.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMDesire.dsf#PHMDesire?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_Desire.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMConfused.dsf#PHMConfused?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_Confused.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMAfraid.dsf#PHMAfraid?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCM_MoleRat_Afraid.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Freak 5/FBMFreak5.dsf#FBMFreak5?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCMF5MoleRat.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Freak 5/FBMFreak5.dsf#FBMFreak5?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/Moles/MCMF5Mole.dsf
    WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking xOrigin & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking yOrigin & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking xEnd & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking yEnd & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking xOrientation & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking yOrientation & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking zOrientation & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLPain.dsf#CTRLPain?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Undead Fiend/MCMFiendPain.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLPain.dsf#CTRLPain?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Undead Fiend/MCMFiendHdPain.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLFlirtingMasculineR.dsf#CTRLFlirtingMasculineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Undead Fiend/MCMFiendHdFlirtingMasculine_R.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLFlirtingMasculineL.dsf#CTRLFlirtingMasculineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Undead Fiend/MCMFiendHdFlirtingMasculine_L.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLFlirtingFeminineR.dsf#CTRLFlirtingFeminineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Undead Fiend/MCMFiendHdFlirtingFeminine_R.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLFlirtingFeminineL.dsf#CTRLFlirtingFeminineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Undead Fiend/MCMFiendHdFlirtingFeminine_L.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLFlirtingMasculineR.dsf#CTRLFlirtingMasculineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Undead Fiend/MCMFiendFlirtingMasculine_R.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLFlirtingMasculineL.dsf#CTRLFlirtingMasculineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Undead Fiend/MCMFiendFlirtingMasculine_L.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLFlirtingFeminineR.dsf#CTRLFlirtingFeminineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Undead Fiend/MCMFiendFlirtingFeminine_R.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: head:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/CTRLFlirtingFeminineL.dsf#CTRLFlirtingFeminineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Undead Fiend/MCMFiendFlirtingFeminine_L.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingMasculineR.dsf#PHMFlirtingMasculineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Skullcrusher Ogre/MCMOgreHdFlirtingMasculine_R.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingMasculineL.dsf#PHMFlirtingMasculineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Skullcrusher Ogre/MCMOgreHdFlirtingMasculine_L.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingFeminineR.dsf#PHMFlirtingFeminineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Skullcrusher Ogre/MCMOgreHdFlirtingFeminine_R.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingFeminineL.dsf#PHMFlirtingFeminineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Skullcrusher Ogre/MCMOgreHdFlirtingFeminine_L.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingMasculineR.dsf#PHMFlirtingMasculineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Skullcrusher Ogre/MCMOgreFlirtingMasculine_R.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingMasculineL.dsf#PHMFlirtingMasculineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Skullcrusher Ogre/MCMOgreFlirtingMasculine_L.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingFeminineR.dsf#PHMFlirtingFeminineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Skullcrusher Ogre/MCMOgreFlirtingFeminine_R.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingFeminineL.dsf#PHMFlirtingFeminineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Skullcrusher Ogre/MCMOgreFlirtingFeminine_L.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMSmileA.dsf#PHMSmileA?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5SmileA.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMSmileA.dsf#PHMSmileA?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5HdSmileA.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMHappy.dsf#PHMHappy?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5HdHappiness.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingMasculineR.dsf#PHMFlirtingMasculineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5HdFlirtingMasculineR.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingMasculineL.dsf#PHMFlirtingMasculineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5HdFlirtingMasculineL.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingFeminineR.dsf#PHMFlirtingFeminineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5HdFlirtingFeminineR.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingFeminineL.dsf#PHMFlirtingFeminineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5HdFlirtingFeminineL.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMHappy.dsf#PHMHappy?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5Happiness.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingMasculineR.dsf#PHMFlirtingMasculineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5FlirtingMasculineR.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingMasculineL.dsf#PHMFlirtingMasculineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5FlirtingMasculineL.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingFeminineR.dsf#PHMFlirtingFeminineR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5FlirtingFeminineR.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D /Evolution/PHMFlirtingFeminineL.dsf#PHMFlirtingFeminineL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/David 5/MCMD5FlirtingFeminineL.dsf
    WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNavelVertical.dsf#PBMNavelVertical?value in file : /data/DAZ 3D/Genesis/Base/Morphs/3D Universe/Toon Amy/FBM3duToonAmy.dsf
    WARNING: fileinput\dzassetdaz.cpp(5288): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Freak 5/FBMFreak5.dsf#FBMFreak5?value in file : /data/DAZ 3D/Genesis/Base/Morphs/joequick/MrTurtle/MCM_TurtleF5.dsf
    File loaded in 0 min 17.7 sec.
    Loaded file: Genesis.duf
    OpenGL error while drawing to the viewport: invalid value
    Loaded Morph Deltas in 0 min 0.0 sec.
    Loaded file: V4_Custom_Milania.dsf
    Loaded file: V5 Custom Shape Eve Body.dsf
    Loaded file: PBMNavel.dsf
    Loaded file: FBM3duToonAmy.dsf
    Loaded file: FBM3duSadie.dsf
    Loaded file: PHMGolemTweak.dsf
    Loaded file: PBMClayShoulderTopoRelax.dsf
    Loaded file: FBMGolem.dsf
    Loaded file: GM1 Walker.dsf
    Loaded file: FBMBehemoth.dsf
    Loaded file: Raw_Satyros.dsf
    Loaded file: FBMFreak5Fibo.dsf
    Loaded file: FBMFreak5Hercules.dsf
    File loaded in 0 min 28.9 sec.
    Loaded file: Clay.duf
    Compiled C:/Users/KMcBriarty/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Displacement.sdl...
    stdin: in function shader_Displacementstdin:440: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying conditionstdin:456: WARNING: 'calculatenormal' function may have unexpected results since 'Pbp' in parameter number 1 is defined in a varying condition
    Compiled C:/Users/KMcBriarty/AppData/Roaming/DAZ 3D/Studio4/temp/shaders/brickyard/{407f8e5c-3a9b-4708-b5e5-799ff1fe7c1d}/shader_Surface.sdl...
    Ran tdlmake on image F:/My Library/Runtime/Textures/Joequick/Golem/ClayLimbsDiff.jpg
    Ran tdlmake on image F:/My Library/Runtime/Textures/Joequick/Golem/ClayEyesDiff1.jpg
    Ran tdlmake on image F:/My Library/Runtime/Textures/Joequick/Golem/ClayLimbs_Disp.tif
    Ran tdlmake on image F:/My Library/Runtime/Textures/Joequick/Golem/EyesDisp.tif
    Ran tdlmake on image F:/My Library/Runtime/Textures/Joequick/Golem/ClayMouthDisp.tif
    Ran tdlmake on image F:/My Library/Runtime/Textures/Joequick/Golem/ClayTorsoDiff.jpg
    Ran tdlmake on image F:/My Library/Runtime/Textures/Joequick/Golem/ClayFaceCarved_Disp.tif
    Ran tdlmake on image F:/My Library/Runtime/Textures/Joequick/Golem/ClayMouthDiff1.jpg
    Ran tdlmake on image F:/My Library/Runtime/Textures/Joequick/Golem/ClayFaceDiff.jpg
    Ran tdlmake on image F:/My Library/Runtime/Textures/Joequick/Golem/ClayTorso_Disp.tif
    Importing File...
    Importing Respect.pz2 ...
    Time to load file: 65.3521 ms
    Imported: Respect.pz2
    Building Scene...
    File loaded in 0 min 0.2 sec.
    Loaded file: Respect.pz2
    Importing File...
    Importing Smash!.pz2 ...
    Time to load file: 58.0515 ms
    Imported: Smash!.pz2
    Building Scene...
    Loaded file: Smash!.pz2
    Importing File...
    Importing F4_Orig05.pz2 ...
    Time to load file: 17.1288 ms
    Imported: F4_Orig05.pz2
    Building Scene...
    File loaded in 0 min 0.1 sec.
    Loaded file: F4_Orig05.pz2
    Importing File...
    Importing V4_01.pz2 ...
    Time to load file: 46.417 ms
    Imported: V4_01.pz2
    Building Scene...
    Loaded file: V4_01.pz2
    Loaded file: VSMOW.dsf
    Loaded file: VSMIH.dsf
    Loaded file: VSMER.dsf
    Loaded file: MCM_RawGrey-REyeClose.dsf
    Loaded file: MCM_RawGrey-LEyeClose.dsf
    Loaded file: PHMEyesClosedR.dsf
    Loaded file: PHMEyesClosedL.dsf
    Merging file Curved Light.daz...
    File read time: 0 min 0.0 sec.
    Building Scene...
    Loaded file Curved Light.daz.
    DEBUG: 0: Toolkit found: C:/Program Files/DAZ 3D/DAZStudio4/scripts/Reality/RealityToolkit.dse
    DEBUG: 1: Toolkit included
    DEBUG: 2: Reality Toolkit v.2.0
    DEBUG: 3: UI created in 0.333 seconds.
    DEBUG: 4: Shutting down the material preview task...
    DEBUG: 5: Done.
    Platform bits: 64
    Qt Version: 4.8.6
    CPU Information:
    Cache Size = 256
    Stepping ID = 4
    Model = 14
    Family = 6
    Extended model = 3
    APIC Physical ID = 2
    MONITOR/MWAIT
    Thermal Monitor 2
    x87 FPU On Chip
    Time Stamp Counter
    APIC On Chip
    PTE Global Bit
    Page Size Extension
    CFLUSH Extension
    Debug Store
    MMX Technology
    FXSAVE/FXRSTOR
    SSE Extensions
    SSE2 Extensions
    Self Snoop
    Thermal Monitor
    Pend. Brk. EN.
    Physical Memory:
    Avail: 10.2 GB (10962546688)
    Virtual Memory:
    Current Memory Usage: 35%
    Current DateTime:
    Loc: Sun Aug 3 15:31:14 2014
    UTC: Sun Aug 3 20:31:14 2014
    Temp Data:
    Disk Avail: 8.7 GB (9442131968)
    Locale: en_US
    Creating managers
    Reading help index
    Using GLEW 1.9.0
    GL_ARB_copy_buffer
    GL_ARB_copy_image
    GL_ARB_debug_output
    GL_ARB_depth_clamp
    GL_ARB_draw_buffers
    GL_ARB_gpu_shader5
    GL_ARB_imaging
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_point_sprite
    GL_ARB_robustness
    GL_ARB_shadow
    GL_ARB_sync
    GL_ARB_texture_rg
    GL_ARB_texture_view
    GL_ARB_timer_query
    GL_ARB_window_pos
    GL_ATI_draw_buffers
    GL_S3_s3tc
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_blend_color
    GL_EXT_blend_minmax
    GL_EXT_Cg_shader
    GL_EXT_fog_coord
    GL_EXT_gpu_shader4
    GL_EXT_packed_float
    GL_EXT_shadow_funcs
    GL_EXT_stencil_wrap
    GL_EXT_texture3D
    GL_EXT_texture_sRGB
    GL_EXT_timer_query
    GL_EXT_vertex_array
    GL_KHR_debug
    GL_NV_blend_square
    GL_NV_copy_image
    GL_NV_depth_clamp
    GL_NV_fence
    GL_NV_float_buffer
    GL_NV_fog_distance
    GL_NV_gpu_program4
    GL_NV_gpu_program5
    GL_NV_gpu_shader5
    GL_NV_point_sprite
    GL_SGIS_texture_lod
    GL_SGIX_shadow
    GL_SUN_slice_accum
    GL_WIN_swap_hint
    WGL_ARB_multisample
    WGL_ARB_pbuffer
    WGL_NVX_DX_interop
    WGL_NV_DX_interop
    WGL_NV_DX_interop2
    WGL_NV_float_buffer
    : NOT INITIALIZED
    VBO supported
    Loading plug-ins:
    aniMate2.dll
    d3dGenX2.dll
    dazscriptide.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzautofit.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzcr2exporter.dll
    dzcustomizedlg.dll
    dzdformeditor.dll
    dzeasyloader.dll
    dzexpexporter.dll
    dzfbxexporter.dll
    dzfbximporter.dll
    dzfiguresetup.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzjointeditor.dll
    dzlayerededitor.dll
    dzlayerfilter.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzmorphloader.dll
    dzobjexporter.dll
    dzprimitives.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzrenderedit.dll
    dzrenderlibrary.dll
    dzsavefilters.dll
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzshadereditor.dll
    dztextureatlas.dll
    dzu3dexporter.dll
    dzwinvideo.dll
    Luxus.dll
    dzdrawstyles.dll
    dzpowerpose.dll
    Reality_2.0.dll
    DEBUG: initDB!
    DEBUG: Db is Open
    Creating interface
    WARNING: Could not parse stylesheet of widget 0xd3c9440
    DAZ Studio Started
    Fragment Shader:
    Linking Shader:
    +++++++++++++++ DAZ Studio 4.6.3.52 starting +++++++++++++++++
    Platform bits: 64
    Qt Version: 4.8.6
    CPU Information:
    Cache Size = 256
    Stepping ID = 4
    Model = 14
    Family = 6
    Extended model = 3
    MONITOR/MWAIT
    Thermal Monitor 2
    x87 FPU On Chip
    Time Stamp Counter
    APIC On Chip
    PTE Global Bit
    Page Size Extension
    CFLUSH Extension
    Debug Store
    MMX Technology
    FXSAVE/FXRSTOR
    SSE Extensions
    SSE2 Extensions
    Self Snoop
    Thermal Monitor
    Pend. Brk. EN.
    Physical Memory:
    Avail: 12.8 GB (13798440960)
    Virtual Memory:
    Avail: 7.9 TB (8795878060032)
    Current DateTime:
    Loc: Sun Aug 3 15:50:01 2014
    UTC: Sun Aug 3 20:50:01 2014
    Temp Data:
    Disk Avail: 11.2 GB (12063318016)
    Locale: en_US
    Creating managers
    Reading help index
    Using GLEW 1.9.0
    GL_ARB_copy_buffer
    GL_ARB_copy_image
    GL_ARB_debug_output
    GL_ARB_depth_clamp
    GL_ARB_draw_buffers
    GL_ARB_gpu_shader5
    GL_ARB_imaging
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_point_sprite
    GL_ARB_robustness
    GL_ARB_shadow
    GL_ARB_sync
    GL_ARB_texture_rg
    GL_ARB_texture_view
    GL_ARB_timer_query
    GL_ARB_window_pos
    GL_ATI_draw_buffers
    GL_S3_s3tc
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_blend_color
    GL_EXT_blend_minmax
    GL_EXT_Cg_shader
    GL_EXT_fog_coord
    GL_EXT_gpu_shader4
    GL_EXT_packed_float
    GL_EXT_shadow_funcs
    GL_EXT_stencil_wrap
    GL_EXT_texture3D
    GL_EXT_texture_sRGB
    GL_EXT_timer_query
    GL_EXT_vertex_array
    GL_KHR_debug
    GL_NV_blend_square
    GL_NV_copy_image
    GL_NV_depth_clamp
    GL_NV_fence
    GL_NV_float_buffer
    GL_NV_fog_distance
    GL_NV_gpu_program4
    GL_NV_gpu_program5
    GL_NV_gpu_shader5
    GL_NV_point_sprite
    GL_SGIS_texture_lod
    GL_SGIX_shadow
    GL_SUN_slice_accum
    GL_WIN_swap_hint
    WGL_ARB_multisample
    WGL_ARB_pbuffer
    WGL_NVX_DX_interop
    WGL_NV_DX_interop
    WGL_NV_DX_interop2
    WGL_NV_float_buffer
    : NOT INITIALIZED
    VBO supported
    Loading plug-ins:
    aniMate2.dll
    d3dGenX2.dll
    dazscriptide.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzautofit.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzcr2exporter.dll
    dzcustomizedlg.dll
    dzdformeditor.dll
    dzeasyloader.dll
    dzexpexporter.dll
    dzfbxexporter.dll
    dzfbximporter.dll
    dzfiguresetup.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzjointeditor.dll
    dzlayerededitor.dll
    dzlayerfilter.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzmorphloader.dll
    dzobjexporter.dll
    dzprimitives.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzrenderedit.dll
    dzrenderlibrary.dll
    dzsavefilters.dll
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzshadereditor.dll
    dztextureatlas.dll
    dzu3dexporter.dll
    dzwinvideo.dll
    Luxus.dll
    dzdrawstyles.dll
    dzpowerpose.dll
    Reality_2.0.dll
    DEBUG: initDB!
    DEBUG: Db is Open
    Creating interface
    WARNING: Could not parse stylesheet of widget 0xd009440
    DAZ Studio Started
    Fragment Shader:
    Linking Shader:
    File loaded in 0 min 10.3 sec.
    WARNING: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
    Sorry for all the posts but I was not sure how else to post the entire log....even though I am pretty sure the entire log was not needed, I just have no idea what part or parts are needed and not needed.
    edited August 2014
    (REMOVED)
    Post edited by SLoTH_XVX on
  • Richard HaseltineRichard Haseltine Posts: 112,003
    We didn't need all of the logs, at most one session and as Mike said just the section covering the loading of Genesis. The could not find errors are not serious - they just mean that you have a morph set that includes corrections to work with another morph set that you don't have - since you don't have it, you don't need the corrections and you can ignore the errors. The HFS morphs and Gwenyth do need updating by their creators to work without errors - these are known issues, I'm not sure if there are product updates available.
    edited August 2014
    You've included at least two cycles of starting D|S, including initialisation of all program subsystems and plugins, loading a scene, and closing D|S. None of that is necessary — new event entries are added to the end of the log, so all you need to do is go to the end, then scroll back up until you come to your load of the Genesis figure.
    A lot of these errors mean the Evolution morph data files are not being found. Did you update these at the same time as you updated the Genesis starter content? How are you doing the updates, using DIM or reinstalling manually?
    Post edited by SpottedKitty on
    Thank you Kitty...(and Richard) I did not realize I only need the 'end' of the log.
    I did not update the Evolution morph data...I don't think? Is that part of the Gen Essential files or is that another product? I normally install manually, I do not use the DIM, prefer to install manually so I can see where the files are going.
    One thing I did figure out...for some reason I never installed the base Freak5 files so I am pretty sure that is what is giving me all the troubles with the figure shapes requiring F5. I am re-installing that set of files next.
    Do I need to set the Female Base shape morph to 100% before using some of the female shapes? A lot of them don't do much outside of the head unless I set the female base to 100%....is that the way it is supposed to work?
    It's a separate product, not part of the free starter content. There's separate head and body morph sets, a bundle of both, and separate muscularity morph and facial expression sets.
    Note that these items end up on sale fairly often, and the big sale season coming up in a few months should also ease the strain on your wallet.
    It depends. If the body shape needs Basic Female (or V5 or any other extra shape), then clicking on a morph in the Content tab should include that setting. Spinning dials in the Parameter or Shaping tabs, though, won't bring in any of these other needed morphs.
    Thanks again for your help Kitty.
    I found the Evolution morphs, I had them just didnt have them installed.
    Everything seems to be working ok now but I am still getting the message because of the HSF files...I will have to see if I have ghe latest versions of what I have....they all seem to work fine but something is throwing the errors on them.
    Did you install the files you already had? If these weren't the current versions, then you would have problems — there were several early Genesis morph sets with major updates, including moving files around inside the /data/ folder (do not try this at home!), and I think I remember this included some of the Evolution sets. Download new installers from the Product Library page and use these instead of your old stored files. Ideally, everything you have installed (the D|S program itself, the Starter Content, all figure morph sets, etc.) should all be the same version.
