Importing v4+m4 into zbrush via GoZ
I hope it's due to me lack of experience but I'm having trouble sending more than one figure to zbrush.
if (for example) in daz I go to the scene tab and select a v4 and a primtive she's sitting on and send to zbrush it works fine in that they both appear in their correct position relative to each other and can be moved around the canvas as one.
However if I try and do the same with a v4 and an m4 they don't appear on the canvas in zbrush together.
Is there something I'm doing wrong?
  • Richard HaseltineRichard Haseltine Posts: 111,721
    I get the same issue with two copies of Genesis - I'm not sure if it's a bug, in DS or ZBrush, or just that it isn't intended to work that way, but it's certainly worth reporting to DAZ (via a support ticket for Technical Support).
