Struggling deleting a keyframe!
solunasoluna Posts: 1
edited October 2020 in New Users
Hi there! I'm ultra new to DAZ and I did my first attempt on animating today. It's been going fairly well except a unwanted movement that I know is caused by a keyframe, as seen here:
However, after watching tutorials, I can't seem to just select the keyframa and delete it? What am I doing wrong?
Thank you!
Post edited by soluna on
  • You screen shot shows only the key markers on the actual timeline, not on the dope sheet for particular objects. I'm not sure how it could get like that, but I think that's why you can't select the key markers for the actual properties - try dragging the divider bar for the graph editor (the one that breaks the vertical white line marking the play head position) down a bit and see if that gives you the node list, from which you should be able to select.
