Problem With "Carousel Diamond Pack," Pole is Transparent
The pole for Diamond Carousel Pack is mostly transparent, pushed a lot of buttons and sliders, can't figure it out. Thanks for any help. Product: https://www.daz3d.com/diamond-carousel-pack
777 x 777 - 77K
  • My guess is it is using a limited range for the Transparency setting - rather than using the full 0 to 1 range and limiting the grey tones used. Unfortunately in Poser the variable is the lower bound, in DS the upper, so the translated value produces a spread from fully transparent to partially opaque instead of the intended partially transparent to fully opaque. One fix you be to go into the surfaces for the part, set the Opacity (or Cutout Opacity, depending on which shader is applied) to 100% instead of its current value (say 60%), then use the Layered Image Editor (from the image menu on the property - click the transparency map's mini thumbnail) to apply a white overlay, and set its opacity to the original opacity value (60% in my example). That should reproduce the intended look, if it was using basic Poser properties.
  • mwokeemwokee Posts: 1,275
    I don't see where you can apply a white overlay but I get something close by checking the INVERT (NEGATE) box.
  • NorthOf45NorthOf45 Posts: 5,898
    Well, you could do that, but (in 3DL) the bitmap used for the Opacity basically washes it out. It is called "WeirdReflection", so I suspect it should go in a different channel. Drop it in the Reflection slot if you want the fake reflection, and turn up the strength regardless (loads at 0%). The colour comes completely from the reflection colour (there is no diffuse colour), so it is basically a mirrored surface, and needs something to reflect.
    800 x 800 - 124K
  • Richard HaseltineRichard Haseltine Posts: 111,430
    edited October 2020
    Add a new layer, set its opacity to the desired value, set its colour to white (with no Resource applied it will just be a solid colour overlay).
    829 x 701 - 59K
