Missing morphs
I have bought and installed 'Gia 6 Pro Bundle' and 'Genesis Evolution: Morph Bundle', but I don't see any morph for Gia. Is there something I have to activate first or a special way to inject the morphes? I do not see something in DAZ 4.6. Someone can help me?
The Genesis Evolution Morph bundle is for the original Genesis figure found in the Genesis Starter Essentials. Gia is a morph for the Genesis 2 Female(s). Make certain you have the Genesis 2 Female(s) starter essentials that comes with DS installed.
The Genesis 2 Female has a head and body morph bundle that is not included in the Pro Bundles. This is a separate purchase. It is not needed to use the Gia morph but may be needed to use other character morphs that are included in the Pro Bundle. Read the product page for required products.
and assuming all is correct, they should be in the "Smart Content" tab under "Figures" (loads everything from scratch, head shape, body shape, skin textures), and the morph sliders should be in the "Shaping" or "Parameters" tab.
I don't have Gia6, yet. As a figure that others are morphs of, the stuff should be in the same place as Aiko6 Olympia6 and Victoria6 (that I do have).
If the sliders are not there, then something didn't get installed correctly, for many possible reasons.
(edit)
For the sliders to show, the G2F figure needs to be loaded into the scene (not Genesis, Genesis 2 Female), and selected in the scene tab.
I forgot to ask, are you using DIM (Daz Instal Manager), or are you installing that stuff another way?
If the sliders are not there, please come back and let us know what is there.
Thanks for the support so far.
I have installed in meantime 'Genesis 2 Female(s) Morphs Bundle' Now I'm able to modify Gia's body and breast almost that way I like. I even was able to make her pregnant, but: I'm still searching for a way to modify that part of her which is used in reality to do this,
When I drag the Attachment 'Genesis 2 Female Genitalia' to her area in question it has a much higher resolution than before and is grey. When clicking on it, still no option to modify her vertical smile is given.
I also did not saw (until now) a texture file to colourize this area. also for that some help is welcome.
I'm using the DIM for downloading the stuff from DAZ
Thanks in advance
OK, in the scene tab, find and select the genitalia thing (with three hexagons).
then over in the "Smart Tab" thing, the menus change.
under "Materials" will be the "Mat" or whatever files for that.
It's the same for the male figures. Or clothing.
Almost anything that has multiple texture options (assuming it has the "Metadata" for the "Smart Tab")
(edit)
My junk has gone gray!? lol.
Thanks zarcondeegrissom,
I followed your advices (I guess I did it often before, because this seems very plausible to me) but I still do not see something where either the name reminds me to the required thing nor I saw - after applying it - the expected result.
Maybe there is still something missing or I need to do one step before to assing the genitalia to the character
no, that display is correct.
from that point, double clock on one of the gia mats. if it dose not look like the correct one, try a different Gia mat. Unlike the guys, the female mats are in the figure mat (for the ones that have such parts).
"O", If the figure is not selected when you load something by double-clicking (Cloths, hair, other parts), the loaded item will not always fit-to the figure automatically (with some exceptions).
Both Genesis and Genesis 2 Female genital props use the Hip material texture map that the figures would use. The G props don't have all the alternate UV mapping options though that the figures do.
Genesis 2 Female is the base mesh. It by default uses the V5 uv mapping and therefore the V5 texture set. All the females of the Generation 6 line are morphs for the G2F base mesh. All of the different Pro Bundles come with the generic female genitals. It doesn't matter if you buy the V6 Pro Bundle or the Gia 6 Pro Bundle. It's pretty much one genital fits all of them. By default, this generic genital figure uses the V5 mapping. While DAZ offers some unique uv sets for some of the G6 line, the genitals are not included. If you pull up the maps for the Gia 6 specific texture, does it even come with genital textures?
