Map Transfer & Displacement
Hurdy3DHurdy3D Posts: 1,113
Hey,
I've baked a multi mesh in sub-d 4 in Blender to a displacement map for a G8M figure.
The dispalcement map is working fine for G8M.
Now I want to have the same dispalcement  on G8F. For this purpose I've transfered the dispalcement  via the DAZ3D Map Transfer tool to G8F.
Sadly, this is not working very nicely:
The reason is that there's some bleeding going on on the displacement map, as you can see if I use the displacement map as the base color texture:
I played with lot of settings (qualility and bleeding slider of the map transfer tool and the resolution of the baked texture 4k up to 16k), but I don't get rid of the the bleeding seam which cause the deformationens and the seams.
Any idea how to fix this?
853 x 1104 - 740K
991 x 1084 - 236K
