Razor Thorn no Wings?
KeryaKerya Posts: 10,943
Question: is it possible to load the Razor Thorn suit without wings?
http://www.daz3d.com/razor-thorn-for-genesis-2-female-s
  • cunningfcunningf Posts: 32
    No. It's an all in one bodysuit.
    The wings do have their own surface setting which can be used to set them invisible.
    I've attached a shot without the wings.
    800 x 640 - 447K
  • KeryaKerya Posts: 10,943
    Thank you for taking the time to help me!
  • scorpioscorpio Posts: 8,533
    The suit appears to use geografting if you set the wings to invisible, you get a hole in the back.
  • XoechZXoechZ Posts: 1,102
    Good to know that, thank you!
    I hate geocrafted clothes, so I will definitely not buy it.
    What about the blades under the arms?
    Do they have an own surface zone too?
    I kind of like the suit (don't ask me why, usually it would show too much belly) - but those appendages are a bit much ...
  • nemesis10nemesis10 Posts: 4,008
    It references something very specific if you google "witch blade anime" so my guess is that the blades were not meant to be accessories to outfit rather vice versa.
    Ooops! Thank you for the warning!
  • Mr BowenMr Bowen Posts: 404
    The Texture Set comes with this. "Blade Covers" "Goes under Suit Blades" It is for when using the "Plasma" effects on the blades. It seems to work well covering the holes when hiding the blades. It can make for a neat look on it's own or with another outfit. I placed some cover on her so I could show it here. It would look cool with some shaders on it.
    1255 x 901 - 458K
  • XenomorphineXenomorphine Posts: 2,421
    edited August 2014
    Oh, darn... I was actually hoping that the blades (or at least arms they are attached to) could be worn on their own. Been in need of lengthy arm-blades to make some 'Bloodrayne' fan-art.
    Post edited by Xenomorphine on
    Thank you Mr. Bowen!
    It get's nudged up on my wishlist again.
