Is there a way to increase the res of dForce Hair
Hey,
is there a way to increase the resolution of strand based dForce Hair?
Sometimes it's looks really low res.
Sadly, there is only the base resolution option.
486 x 384 - 221K
Depending on whether the hair is using root radius or target surfaces, you can increase either the pre-render points per hair, or reduce the pre-render interpolation segment length in the surfaces tab. Beware that overdoing it can become very resource intensive, and adjusting the pre-sim rather than the pre-render settings can drastically change how the hair will drape during simulation, so best to just change the pre-render settings.
