photoreal and interactive render
photoreal and interactive render i have a question i\m having troubel rendering genuses 8 in interactive i keep getting funny shapes and colours on iteams of clotheing or hair i tryed the cut out transpercy and it still will not work why is this doing this its only with genuses 8
988 x 881 - 235K
988 x 881 - 542K
  • For the skull caps try making them just a little bit smaller. If made too small then the hair will also be pulling into the head.
    You could try making a morph for the top of that dress to do the same thing [save morph for repeated use] or use the geometry editor brush to select and then delete that geometry. That would be a one time use fix though as the morphs etc. would be broken. So pose first then cut out.
    There are technical reasons 'why' - and I'm not the person to explain them.
  • thank you i really have no idear how to morph or a geometry editor brush
  • LenioTGLenioTG Posts: 2,118
    Me neither.
    What you can do, is that some hair include morphs, to make that forehead portion go into the skull.
  • nonesuch00nonesuch00 Posts: 18,897
    1) Hair
    a) On the scaling part of the hair once fitted to the model, adjust the Scale to 99.5, 99.0 and so on smaller until the haircap is not visible.
    b) Or you can use the Tansparency Cutout slider on the hair cap and slide it to 0% to make the hair cap not visible. Sometimes that makes the character look a bit bald though.
    2) Clothes
    a) The clothing in your 1st picture shouldn't have such an outline on the upper dress and the eyes' scerlas  should not be so darkly colored. That is an old bug in DAZ Studio/.nVidia iRay for which the only solution is to move the character(s) you are rendering to as close to (0, 0, 0) as you can get. By the way, moving the character as close to (0, 0, 0) as you can get for the character in 1) might fix the problem there too. I'm not sure of all the details of your scene.
    You don't mention what version of DAZ Studio you are using but that bug is fixed in the newer released version of DAZ Studio I think (4.12.1.118) but it has maybe other bugs you might not like but it you don't do animations you will be happy with DAZ Studio 4.12.1.118 if you haven't already got it.
