strange pattern after rendering ?
AristocAristoc Posts: 254
edited July 2014 in New Users
This is Loft 4 Lease with the Dance Studio Add on by Predatron.
I have installed and re-installed with no improvement. It looks like the Loft4Lease underneath is peeking through the add on.
should i be doing something else?
Thanks
600 x 428 - 312K
Post edited by Aristoc on
  • LeanaLeana Posts: 13,667
    It looks like you have 2 copies of the loft loaded.
    The add-on is a probably a complete scene which loads the objects too, so you don't need to load the original version.
  • AristocAristoc Posts: 254
    That's what I have been doing.
    Loading the original and then loading the add on scene.
    I thought that usually you have to load the original and then an add on.
    I will try your suggestion and load the add on by itself.
    Thank you.
    You need to load the original first if the add-on is only materials, but if it's a complete scene then it's not necessary.
    Yea, I usually just try adding the "add-on" first, if it complains then I know it needs the base whatever.
