New DS Filament Render Engine
SevrinSevrin Posts: 6,313
edited October 2020 in The Commons
So I'm liking the Filiament preview feature in the DS beta.  It's not Photoreal, but it's what I'll be using instead of texture-shaded, for sure.  Very fast, and gives a better idea of what's going on.
Texture-shaded
Texture-shaded
Filament
Filament
Photoreal
Photoreal
921 x 1201 - 201K
918 x 1203 - 365K
922 x 1200 - 149K
Post edited by Sevrin on
«13456730
  • SevrinSevrin Posts: 6,313
    edited October 2020
    With that said, ahem, it's not a complete substitute for texture-shaded, especially if you depend heavily on emissives for your lighting.
    Texture-Shaded
    Filament
    Filament
    Photoreal
    Photoreal
    1464 x 1096 - 340K
    1465 x 1099 - 147K
    1463 x 1097 - 290K
    What might be of particular interest to animators, is that this 38 frame video took 12.49 seconds to render, start to finish.
  • 3Diva3Diva Posts: 11,998
    Oh nice! I was about to ask if it can render an animation!
    Now that Is really Nice!
  • That's going to make a lot of people happy!
  • GordigGordig Posts: 10,645
    Downloaded the beta, loaded up an animated scene, switched to Filament, hit play. I can actually see it move through all the frames instead of just bouncing around. This is so much better.
    edited October 2020
    I don't know if there's a better way to do this, but there's a new "Viewport" option in the Render Engine selection drop-down.  That's what I used.  Like with OpenGL, you have to keep the viewport free during rendering.
    567 x 402 - 44K
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,409
    they must have added that beta after I used DIM today
    opens DIM eagerly
    looking good, crashed Studio already first go but might have been a bit keen with 10 instances of a dressed Dforce G8F I saved earlier
    viewport cool
    edited October 2020
    It looks like Filament Renders just about as fast as Open GL (at least on my machine). With the same animation, the Open GL render animation took 11 minutes and 5 seconds, the Filament render animation took 11 minutes and 28 seconds.
    Texture Shaded Open GL (11 minutes, 5 seconds):
    https://player.vimeo.com/video/467992557
    Filament Render (11 minutes, 28 seconds):
    https://player.vimeo.com/video/467993040
    The hair looks weird in the Filament render, but that might just be my shaders. And I couldn't figure out how to get the Environment Backdrop to show up in the Filament render. I'll have to do some more experimenting.
    Post edited by 3Diva on
    very cute 3Divaheart
    +1
    +1
    Thank you, guys! It's my first time hand animating (I don't know if that's what it's called) - posing and setting up the keyframes by hand rather than using Puppeteer or Aniblocks.
    my first look at Filament
    can see artifacts but considering that same render just the dressed animated Viking maiden took 8 hours in iray
    about 30 mins with the Red crow architecture prop pretty fast
    edited October 2020
    Is there a way to uninstall texture shaded view?
    edit: Oh my God I just saw the tonemapping options in the scene view.
    Post edited by Gordig on
    Yeah, what IS that?
    Yeah, what IS that?
    Amazing.
  • IvyIvy Posts: 7,165
    edited October 2020
    Defiantly a difference between iray and filament render quality.  i wonder if filament baked/render,what ever you want to call it longer if it would clear up the artifacts?  I'm holding off on over writing my copy of the beta I have for now so maybe after i know you guys are not getting any bugs I'll update  my copy.
    @3Diva Nice job on your first animation smiley
    Post edited by Ivy on
    edited October 2020
    I changed the shader to the base Iray Uber shader and turned the dome on and rerendered it with Filament preview. This time it rendered even faster at 10 minutes and 44 seconds:
    https://player.vimeo.com/video/468002998
    Edit: The hair still looks weird. I'm not sure why. Perhaps the trans maps.
    Thank you, Ivy! :) I did a couple of other test animations before this (mostly with puppeteer), but this is the first time doing one that I hand did the keyframes. So I'm happy I was able to figure out how to do that! :)
    edited October 2020
    That's smart because I've already discovered a bug - trying to do an Iray render with anything in the scene that has the Oso Blendy shader applied immediately crashes Daz Studio. This is a bug that keeps popping up EVERY SINGLE beta release and it drives me BATTY. If they know that it's an issue, and it's been a problem like the past 3 or 4 releases, why oh why do they still not implement Blendy support with the release? ARGH! :(
    Just tried out Iray section planes and decal nodes, and neither worked in Filament. I wasn't expecting them to, but it would have been nice if they did.
    Gordig said:
    Yeah, what IS that?
    Amazing.
    Seriously, what does it do? I just see two new items in my scene tab. One says "Tonemapper Options" and one says "Environment Options". What do they do? How can you adjust them? Or what is their purpose, do you know?
    They do exactly what you would think: adjust tonemapping and environment settings from the scene pane, and see realtime results (though not for all parameters).
    edited October 2020
    Dropped a character into a dark environment with a default spotlight on her face, lowered the exposure until I got this:
    1371 x 664 - 575K
    edited October 2020
    Out of curiosity, I did a quick Iray render with the same settings:
    So...looks like Filament hasn't made Iray preview mode redundant.
    1200 x 1600 - 3M
    edited October 2020
    Ok so opening up a fresh scene and it looks like Tone Mapping and Environment Settings are gone from the Render Settings Tab. Which is extremely weird. Where are they?
    I only had them in the scene I was working in because I had saved the scene in the previous version of Daz Studio which, of course, had tone mapping and environment settings. But they only showed up then as weird "add on" objects in the scene. Why aren't they in Render Settings anymore? And how can I add tone mapping or adjust the Environment Settings in a new scene (since they're MISSING now... wth?).
  • namffuaknamffuak Posts: 4,457
    Select them in the scene tab - and the settings are now in the parameters tab.
    edited October 2020
    If you start a new scene they're not in the scene tab.
    Edit: Apparently if you want Tone Mapping and want to adjust the Environment Settings you have to MANUALLY add them to the scene tab by going to "Create" >> "New Tonemapper Options Node" and "Create >> "New Environment Options Node". *sigh* I don't understand the logic behind this move. It's an unnecessarily complicated added step that will now make tweaking the tone mapping and environment settings more difficult because now you have to find them in the Scene Tab among all the other props, characters, lights, and cameras in the scene.
    Edit 2: It appears you can get the Environment and Tone Mapping back in the Render Settings Tab by switching back to the Iray Engine. Whew! Thank goodness! lol surprise
    Interesting - look under 'Create' - remember to do Window -> Workspace -> Update and Merge Menus first; may be needed.
