I can't load genesis 2 morphs in poser 2014
faisanfaisan Posts: 602
edited July 2014 in The Commons
I can't load genesis 2 morphs in poser 2014, only the figures, and I installed all the files comes in the folders of posercf and the other one, but poser only loads the figures like in the pic. I have to tell I installed Genesis morphs and I didn't have problems with them, only with genesis 2 morphs. Could someone tell me what i'm making wrong? Thank you
Image removed
  • Richard HaseltineRichard Haseltine Posts: 111,723
    edited July 2014
    How did you install - manually or with the DAZ Install Manager? Did you install the core files as well as the PoserCF files?
  • faisanfaisan Posts: 602
    I installed manually, yes I installed all files, like genesis 1, with genesis it worked, but with genesis 2 morphs I have problems. I did the same process for both figures, that's why I don't understand why in genesis 1 it worked and in genesis 2 it didn't.
    Btw I noticed the image was removed, I guess it was because was a nude figure, sorry, I forgot it.
    Will the problem be Poser 2014 needs the SR3.1 which I think it's the latest SR?
    The DSON Importer for PP2014 should, as far as i know, work without the SRs - though it's generally a good idea to have them. Do you only the one Data folder, with entries under DAZ 3d for Genesis and Genesis 2? What folders does the \data\DAZ 3D\Genesis 2\Female\Morphs folder contain?
    it contains : \Morphs\DAZ 3D\and it has 3 folders: Base, Control Rig, and Teen Josie. for Base it has 478 DSON Support Files; for Control Rig 1440 and for Teen Josie 19
