Mouse pointer disappearing.
ewangrant1
Just started this morning, mouse pointer just disappears. Restarted windows to no avail. It is only in Daz this is happening. Even minimising Daz shows the pointer still on desktop, and other programs tested successfully without issue.
Any ideas?
This is usually a Graphics Card issue, have you recently updated any drivers?
You could try going to Edit > Preferences > Interface and set the Display Optimization to 'None' to see if that helps.;
You could also use Window > Workspace > Select Layout, and change it temporarily to see if that works, then change it back to the original.
No driver update in last couple of months.
Display optimization is already set to None.
Wish I hadn't tried the last one, I had a customised City Limits which wasn't saved - as I discovered when I tried to set it back the way it was. :D
http://www.daz3d.com/forums/discussion/43626/
If you google Mouse Disappears In Daz you'll get some more threads :)
Maybe try changing to wireframe view, then back to smooth shaded. See if that helps
Ok, thanks for that linked thread. Good to know that they are aware of problem and working on it.
For now, it seems to work for me changing to wireframe and back as you suggested so thanks for that too.
