how can I creat this kind of black effect
In FG Cowgirl (SKU:73617)
The characters in the picture are black, glossy, almost without reflection, with a deep feeling.
How can you set such a skin effect?
  • kyoreonakyoreona Posts: 222
    https://www.daz3d.com/fg-cowgirl-outfit-for-genesis-8-females
    I don't know why I can't upload pictures.... pls check the link
  • RobinsonRobinson Posts: 751
    Get glossy reflectivity to 0, reflectivity to 0, clear the translucency and base colour maps away (set to none) and set their colour to black.
    Also a closer look appears to be either rim light or some kind of post-process outline too.
    Thank u sir ~but why can't I find "reflectivity , translucency "you mentioned in parameter ?  Is that whole name ?
    And , I try to clean all maps to "none", and make it black , finally , I got the effect I want .
    But if I change the color to pink ,for example , the effect is not good , I can see the body line very clearly ...
    They're in the Surfaces pane, not the Parameters pane.
    Thank you sir !yes
