Backdrop image, how do I make it show up in renders?
Sand3Sand3 Posts: 101
Using DS4.6
So I have a backdrop image loaded up onto my stage that I wanted to use as part of the background when I'm rendering, but when I render it disappears, like maybe the 'backdrop image' under the edit menu is just for previews and placement and stuff? So then where do I go to load in a background image that I want to show up on the final render?
  • fixmypcmikefixmypcmike Posts: 19,741
    When you render to an image format that allows transparency, like .png, the backdrop is in the alpha channel. Either render to a different format (like .jpg), or use your 2D image program to display the backdrop.
  • FirstBastionFirstBastion Posts: 8,089
    Exactly as Mike said, save as jpeg or bmp and the backdrop image will be there as part of the render.
  • Sand3Sand3 Posts: 101
    I did that. In JPEG format, it makes the background white, no sign of the backdrop.
