Render resolution scale missing?
DekeDeke Posts: 1,636
Okay I give up…somehow the little resolution meter on my Daz Studio render panel is missing…the one with the woman's picture and how you can set it to render in low or high resolution. It vanished. Any idea on how to get it back?
  • Scott LivingstonScott Livingston Posts: 4,352
    Might be that it's minimized. If so, on the Render Settings pane, right at the top, just below and to the right of the "General" and "Advanced" tabs, there's a little thing you can click on which will un-hide it. On mine it's a tiny dark gray rectangle; yours might look different depending on your layout (it might look like a white triangle, for example).
  • DekeDeke Posts: 1,636
    Yep, that did the trick. Thanks.
    And boy do I wish those little arrows were actual handles and that I could control how open or closed those panes are.
    No problem. And some of them (not that one, but some of the others) are sliders--just click and drag somewhere else along the dividing line, not directly on the arrow.
