Active Camouflage
dmurray3132dmurray3132 Posts: 24
By any chance, does any one have techniques on creating active camouflage on Carrara or even DAZStudio?
I'm pretty sure it's simple but I'm cheating a bit by asking you guys.
And you might have better ideas
Thanks in advance
    Thanks in advance
    ? active
    There are camouflage filters for 2D texturing.
    I agree with Patience. A bit more information is needed. I don't know what active camouflage is. I know what camouflage is, but don't know the distinctions.
  • dmurray3132dmurray3132 Posts: 24
    edited July 2014
    Shame on me for making assumptions. Best example would be "Predator" or as in "Halo." As in the picture
    I may have figured the texturing part out. I just need to figure out how to animate the transition.
    Thanks guys, you have never been late with the help.
    455 x 341 - 44K
    Post edited by dmurray3132 on
  • Eva1Eva1 Posts: 1,249
    edited July 2014
    Thanks in advance
    If you don't want to make them yourself, I've just released a combat shader pack that you might find useful - they are fabric shaders but could probably be applied to general objects, depending on the scene:
    http://www.daz3d.com/new-releases/fabulous-fabrics-combat-preset-shaders-for-daz-studio
    EDIT: Ooops - sorry, didn't see the post about animating - guess my shaders won't be much help then.
    Post edited by Eva1 on
  • waxfin_c9ea3eab69waxfin_c9ea3eab69 Posts: 58
    animate the transition?
    in the shader room use a mixer parameter for your character
    put one texture in source 1
    put t'other texture in source 2
    in the blender part you could use a 1-100 slider
    at frame 1 use a value of 1
    at frame 100 or whatever use a value of 100
    you could also animate it with a black and white avi in the blender section
    if for example you wanted a ripple effect in the transition you would use a ripple animation,
    but the timing becomes harder I think
  • SimonJMSimonJM Posts: 6,106
    May not be what you want, but (at least) one of Dimension Theory's nature-based shaders is a 'camera-based' shader, so as the figure moves the material/shader on it changes too.
    Man I love this forum.
    Thanks guys,
    I'll try these this weekend
    As Headwax suggested, you could use a mixer to transition, but I think C8 and on has a master shader mixer or something that operates essentially the same way, except it should be able to blend the entire multi-channel shader instead of having to do it by Color, Highlight, Shininess, Bump, etc, etc.
    As to the effect of the active camo, I would think that a transparent shader with a Fresnel value and refraction would do the trick. Probably a touch of reflection as well. If it's still to visible, use the alpha channel with a 1-100 slider to fade out the visibility to the desired level.
  • pwiecekpwiecek Posts: 1,598
    Poser shaders have a refraction channel. If you have something equivalent, try experimenting with that.
    Carrara has a transparency shader with a fresnel option (the refraction shader must be enabled), absorption and in-scattering.
    Carrara has a refraction shader plus a bunch of IOR profiles (Index of Refraction), or you can use any other procedural function.
    There is a separate alpha shader that can also be used, but it has no refraction.
