FBX export options not working.
Kooreo
So I check the show FBX dialog. Once it opens I change it to no hidden which should make it ignore any hidden items on the model but once exported it still exports the hidden items. Also tried selected which should only do the selected model but it still exports everything.
If I do this without the Daz to unreal export aka a normal FBX export theses options work fine.
Can you fix this?
Post edited by Kooreo on
Is this separate items you are hiding, or bones within a figure?
Clothing, Hair, etc...
Do you have the Merge Skeletons for followers option on?
I think I was checking this recently and those options didn't work like I would expect with clothing that was merged with the character. I might have been testing with the plugin though, so maybe there's another setting I used that conflicts. I'll take another look.
Does not matter if it is on or not all options in the fbx menu settings are broken with the plugin and don't work. I have tried a mix combination of most of the settings and every time it ignores the fbx setting and imports everything. Even if I uncheck all the options.
The normal fbx export works fine so the plug is broke something somewhere but doing it through normal fbx you have to manually import the missing texture files that daz does not export and manually set up missing textures in the materials in unreal plus fixing the eyes and hair manually.
So at this point, it's just trading one problem for another.
I have the same problems as you except for me ,the plugin work fine , it is the normal FBX export that don't work.
That the option I choose, but the hidden mesh are still exported:
https://ibb.co/Yf8dZXh
I dont know if I do something wrong , anyone had this problem?
You would be better off asking on his discord. https://discord.gg/rSSdPzBQwn
Thank you
