DIM and Daz Central
Silly question I expect, LOL! Can I remove DIM if I now use Daz Central?
  • LeanaLeana Posts: 13,656
    You don't need DIM installed to use DazCentral
  • lindanslindans Posts: 99
    edited October 2020
    I thought that was probably the case, but best check LOL!
  • nicsttnicstt Posts: 11,715
    or you can remove Daz Central and keep DIM
    choice is yours. From what I've seen DIM does more; it is good for finding stuff too.
  • fixmypcmikefixmypcmike Posts: 19,742
    Note that DazCentral will use your DIM settings.  For example, DIM can install software and content to different locations, and can be told not to delete the zips after install.  You can't set DazCentra to do tht, but if you set it in DIM DazCentral will obey.
