hello what would be causing this?????
hello i finally got my iray going but what would be causing the funny shadow mark on her upper body ???? it only happens in inractive mode not photoreal
988 x 881 - 229K
    Does the dress use transparency maps?
  • i know this is going to sound like a stuip question but where do i find that ????
    In the Surfaces pane's Editor tab, you have to have the item selected then click onits name in the list, or pick individual surfaces (a quick way to do both is to use the Surfae Selection tool from the Tools menu) and type Opacity in the filter box at the top of the pane. You can then see if there are maps assigned to the (Cutout) Opacity property.
  • only thing i could find was this
    386 x 573 - 52K
  • ok is this what you mean
  • is it this
    209 x 137 - 10K
  • Yes, Cutout Opacity is the property in the Daz Uber Base Iray shader - and it does have a map assigned (the little black-and-white image to the left is a micro thumbnail).
  • ok ill show you
  • TBorNotTBorNot Posts: 386
    Do you mean the shadow of her arm?  I'd try rotating the dome, "Render Settings tab, Environment, Environment Mode",  does "Dome" appear in the selector?  If so, "Dome Rotation" is fun to play with since the lights go around with the dome.
