Unlock region tool
albert.karinalbert.karin Posts: 0
Hello Forum Members,
I think i have accidetly (de)activated a part of my character with the region tool i think.
Now i cant select anything from my character below the waist.
Also when i apply a pose the character implemets the pose a funny way and the lioncloth is stuck to the legs while that was not an issue before i messed with the tool thingies.
I cant find how to restore the selectability etc of my character.
  • SzarkSzark Posts: 10,634
    edited July 2014
    look in the Scene Pane and see if there is a small X beside the offending Parts, If there is then click on the small x and it will change to a Tick and try again.
    If there are numerous parts that cannot be selected then select them all in the Scene Pane by selecting the top or bottom part, hold down Shift and click on the opposite end highlighting all the parts. Then pop in to the Parameters Pane > Display > and make sure Selectable is ON.
    1680 x 1050 - 588K
    Post edited by Szark on
  • albert.karinalbert.karin Posts: 0
    edited July 2014
    I was aware of the parts need to being ticked in the Scene Pane, I checked it anyway in a fully expanded scene pane.
    The solution of the problem isn't there.
    If i try to select a leg part in the Scene it only selects the background.
    This concerns only everything that is between the pelvis and the feet, including the loincloth drape
    I can select these from the Scene Pane an then adjust them from the parameters pane, but then the shoes and loincloth drape follow in a strange way.
    All selectable sliders are ON.
    So there is still some strange problem.
    Maybe i can retrieve the proper functioning figure from an earlier saved scene in to my current scene?
    Post edited by albert.karin on
    ok what tool are you using to select the part...have you the right tool?
    edited July 2014
    With the universal tool activated when pointing with the mouse on a fugure (or any item) it higlites the pointed item and then you should be able to select the item to modify or apply morphs.
    As you can see in the picture pointing at pelvis, abdomen and feet works fine,
    Pointing at shin, loincloth or thigh it highlites the item that is in the background, like in this case the wall or the door.
    It looks like the shin, loincloth an thighs are "invisible" for the mouse pointer.
    At some point during my work on the scene this phenomena appeared.
    Probably i did something stupid at that point.
    1008 x 752 - 234K
  • Richard HaseltineRichard Haseltine Posts: 111,984
    edited July 2014
    Are you absolutely sure you have not checked off the Selectability - the little arrow icon should have a tick, not a cross, as shown below.
    248 x 41 - 9K
    edited July 2014
    Looks like all items are ticked.
    I have copied the (bare) figure and the copy seems to work ok.
    469 x 779 - 59K
    has me stumped, sorry. At least the copy works. ;)
