How Do You Get This to Work: iRadiance HDR Resources - Parks and Rec Vol 1
I click on it, and nothing happens. All the other HDRIs I have, you click on the one you want and hit Render and you get a scene.  What do I have to do with this to get it to work?  https://www.daz3d.com/iradiance-hdr-resources-parks-and-rec-vol-1
Thanks
    Is that a pre-Iray product? If I remember, you have to delete the dome meant for 3Delight and just plug the HDRI image in the correct spot.
  • TaozTaoz Posts: 10,371
    edited September 2020
    Looks like it's a sort of merchant resource pack, without presets.  I guess you can just load the HDRIs into the Environment Map slot.
    Post edited by Taoz on
    It mentions Uber Surface which is a 3Delight shader.
  • I don't click and load any settings
    I just whack the HDRi, EXR or tiff files onto my environment dome and use the default or my own settings
  • Don't use the environments or shaders tab. The Render Settings tab will load the HDRI and apply dome rotation of 0 degrees. The other preset: Rotation options will just rotate the dome - you can do that also manually in the render settings->Environments. Tone Mapping and White balance will change the related areas in the render settings as well. The presets kind of gives you a visual clue e.g. how the white balance is affected.
  • FauvistFauvist Posts: 2,291
    It is the IRAY version.
    "I just whack the HDRI, EXR or Tiff files onto my environment dome" and "the Render Settings tab will load the HDRI" sound wonderful.
    I look at the Render Settings tab, and I see an Environment Map slot with the instructions "Choose Map".  So, where is the map?  What is the name of the map?  With other HDRI products I've purchased I click on the icon of a beach, and it loads the beach into the Environment Map slot.  I have probably hundreds of HDRIs at this point.  If it doesn't load when I click on the icon, how am I supposed to find it?
    986 x 1870 - 249K
    on my Mac, the file path is /Users/Shared/My DAZ 3D Library/Light Presets/DimensionTheory/iRadiance/Merchant Resources. But you can just double click on any of the spheres in the upper part of the Render Settings section of the product
    920 x 1574 - 565K
  • Charlie JudgeCharlie Judge Posts: 13,659
    Content/Runtime/Textures/DimensionTheory/RefmapRES/Outdoor
