Gen 3 male suddenly a kid
Somehow my Gen 3 base male has turned into a kid.
I have to keep on zeroing him in EDIT - FIGURE.
It's a bit annoying. How do I restore his default?
With the figure kiddified go to the Currently Used group in the Parameters pane - there's probably a non-zero shape there. If you can identify the culprit please reprot it to the author or store, in the meantime you can either uninstall the character that is causing the issue or you can edit the property to have a non-zero default value (zero the figure, click the gear icon on the sider for for the problem shape>Parameter Settings, set the default value to 0, and File>Save As>Support Assets>Save Modified Assets; you may then want to reinstall the base Genesis 3 Starter Essentials as I think some values on that may get changed in the process.
Ah ha. thank you muchly, Richard.
