Simulating Closes Daz [RESOLVED]
OminousAutumnOminousAutumn Posts: 405
edited September 2020 in New Users
Hi all,
Everytime I try to simulate a dress on my G8F, it just shuts down when it used to simulate just fine. This is a new problem so no clue where to start really. Any ideas? Thanks!
Post edited by OminousAutumn on
  • Hello!
    Which dress is it? Is it just the one dress or is this happening with other dForce clothing for you as well? Also which version of DS are you using the live version or a beta build?
    Elli
  • Hardware specifications, OpenCL device selected in the Advanced tab of Simulation Settings, its driver version, DS version?
  • Elliandra said:
    Hello!
    Elli
    It is the dForce Wisteria dress. I am running 4.12.1.118 Pro Edition 64 bit. I will see if I have any other dForce items i can try. I tried adding a dForce modifier to something else but that was hopeless.
    I am running 4.12.1.118 Pro Edition 64 bit.  the OpenCL is Apple GeForce GT 750M. Worked fine not that long ago...I have two other OpenCL options. Iris Pro, and an Intel one.
    Try the others, see if either works
  • If that's Nirvy's dress from Rendo it's one I don't have so I can't check it on my system crying  I have come across a couple of dresses that crash DS but that's due to poke through into the base mesh and I just use Mesh Grabber to pull it out a little and then it's fine.
    I dont think its the dress. I have a dForce Duvet that worked like a charm not lot ago and now simulating just closes the application. Ugh.
    It worked. I swapped to another one and it told me about "kernels" needing to be reset or something. Thank you.
